anyone have those cams?
A while ago someone here mentioned that they had motec and custom Camshafts on their SC400 putting down like 300WHP. Does anyone in US have have these cams? also does anyone make pulleys for the SC400? searching returned massive results but all for SC300's.. maybe I missed it.. any info would be awesome.
C's makes a set of cams for the 1UZ, otherwise you can deal with the Australians, or call Brian @ Crower and see if he can help you, but that's a lot of cams to regrind amigo
For pulleys you may have some luck calling UR, they're located not too far from you, out East by me...
.....For pulleys you may have some luck calling UR, they're located not too far from you, out East by me...
Cams,lets see..Webcam in Australia,or Kelford,also in Australia say they can do it,but are very slow to respond to emails;I gave up waiting.
Was actually thinking of making my own pulley;4" diameter would give a 30% decrease in rpms for all those pumps and other rotating stuff.
I wish I knew how critical the harmonic dampener is to the life of these motors first,however.
82mm stroke w/a forged crank,my first guess is to just go for it,but...
UR=who are they?
You can now buy hot cams ready to go. 50 hp at the flywheel - not estimated by done on an engine dyno. I wish they were available when I did my cams. Good idea to get some custom headers installed same time - not that hard - if your regular exhaust shop baulk at the idea then go to a hot rod shop who are comfortable with custom work.
The cams are available from Carbontech - a place in Victoria Australia.
http://carbontech.com.au/
Look under lexus mods
