Fuel pump problem
Old Mar 5, 2015 | 04:07 PM
jose2015's Avatar
jose2015
Red face Fuel pump problem
Hi fellow Lexus owners can anyone help me locate the circuit opening relay for the fuel pump on my 92 SC4OO much obliged . Thanks
Old Mar 6, 2015 | 03:55 AM
gerrb's Avatar
gerrb
Super Moderator
Not sure if I am understanding you well but if your question is Pump Controller... the fuel pump ecu is on the side panel behind the driver seat, that in turn is controlled by your Car ECU.
Old Mar 6, 2015 | 08:05 AM
jose2015's Avatar
jose2015
there is an EFI relay before the fuel pump ecu and an circuit opening relay that runs the EFI to run the fuel pump
Old Mar 6, 2015 | 10:15 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
The EFI main relay is in the relay/fuse box in the engine compartment. There is a diagram located on the underside of the lid that will show you exactly where it is.
Old Mar 6, 2015 | 11:35 AM
jose2015's Avatar
jose2015
Unhappy fuel pump
I know, what i need is the circuit opening relay that feeds the EFI relay found under the hood
Old Mar 6, 2015 | 12:22 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
whats the symptoms. usually don't have to mess with the COR. normally what goes bad is the fuel ecu, but if you are getting no 12V whatsoever anywhere in the car the check out the COR and the M-REL.
if you are getting 12v and the pump is just not turning on, then try jumping +B and FP on the diagnostic connector. if they fuel pump comes on then probably a bad fuel ecu.
Old Mar 6, 2015 | 12:32 PM
jose2015's Avatar
jose2015
We have installed new pump everything is good except power to the EFI relay which is supplied from the circuit opening relay if I give the EFI direct pwr the car will run but you turn it off and on , back to same problem,now the EFI relay get its on pwr from the circuit opening relay just can't find it some say it's a relay next to the engine ECU/ECM ??
Old Mar 6, 2015 | 04:56 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
If you're not getting power to the fuel pump, check the 30 amp fuse for the injectors.
Old Mar 9, 2015 | 12:52 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
check the M-REL wire at the ecu or if you did any wiring around there. that is the signal wire that turns on the whole efi system unless I am remembering incorrectly.
COR is part number 5 "28300" according to this diagram, not positive if its correct though.
http://www.lexussouthatlantaparts.co...=0&modelYear=0
Old Mar 12, 2015 | 06:24 PM
jose2015's Avatar
jose2015
Unhappy
Well guys and gals looks I need an ECM for my fuel pump problem does anyone know where one can be had for a reasonable price ? also what year models would work mine is a 92
Old Mar 12, 2015 | 06:39 PM
6SOARER's Avatar
6SOARER
Classified section, hit up Aliga. He can get you just about anything for your SC.
Old Mar 13, 2015 | 09:47 AM
jose2015's Avatar
jose2015
Does anyone have or can tell me how to get the wiring diagram for a 92 SC400 ECM for pin routing
Old Mar 13, 2015 | 10:32 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
lextreme has them
http://www.lextreme.com/misc.htm
Old Mar 13, 2015 | 11:53 AM
jose2015's Avatar
jose2015
Lextreme only show the ECU diagram I need the ECM diagram
equix8
Jan 3, 2015 09:04 AM
pyr8
Dec 22, 2014 08:26 AM
KickItOut
Feb 3, 2013 04:21 PM
sc300vroom
Nov 7, 2009 08:31 PM
dave_id
Oct 24, 2009 01:43 AM
