Where does this hose belong
Old Jan 21, 2015 | 10:27 PM
Marklopez's Avatar
Marklopez
Default Where does this hose belong
Okay so me and my friend did the tune up on his car. We put everything back and the car was idling high and surging up and down. We found that we didint connect this hose that supposly is fuel related. The mechanic told us to take everything back off and it would be under the intake mani. I really can't seem to find where it goes. It hasent ripped. Car runs great until stopping or in park. Help please
Old Jan 21, 2015 | 10:28 PM
Marklopez's Avatar
Marklopez
Hose is coming from the passengers side
Old Jan 22, 2015 | 02:32 AM
gerrb's Avatar
gerrb
Super Moderator
There is a vacuum diagram under the hood where you can trace the routing of hoses . It might help .
Old Jan 22, 2015 | 10:14 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
moved to maintenance.
where is that hose coming from, you are just holding a hose in that picture. maybe stand about 3 feet back and snap a picture I know where pretty much all of them go.
your PCV looks broken (purple plastic thing on valvecover) but that hose is too small to be the PCV hose. Also it does not look fuel related as its too thick to be the vacuum line for the regulator and too thin to be the return hose, not to mention if it was the return hose it wouldn't drive fine it would be spraying fuel everywhere.
Old Jan 22, 2015 | 10:44 AM
Marklopez's Avatar
Marklopez
I belive it's coming from the canister but I'll send one as soon as I get to my friends house
Old Jan 22, 2015 | 11:32 AM
Marklopez's Avatar
Marklopez
Old Jan 22, 2015 | 12:47 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
the one coming from the canister goes into a metal line right next to the EGR. that metal line has several vac hoses on it that run under the Y part of the intake, but there is one nipple that comes off that metal line that points up and towards the egr/canister side of the engine bay and that is where that hose goes. If you follow that metal line it will go to a Tee and one side goes to the EVAP vsv, and the other side of the Tee goes to the blue check valve under the Y part of the intake, then it goes up to one of the 3 ports on the throttle body for Evap (canister system).
you can see it on that diagram above where it comes off the canister and goes to a Tee, but it doesn't show the metal lines.
Old Jan 22, 2015 | 02:19 PM
Marklopez's Avatar
Marklopez
Thanks man I really appriciate it I hope I can have it runnin good by tonight
khoality
GX - 1st Gen (2003-2009)
Jun 2, 2017 06:54 AM
anon1m0us
Jan 24, 2017 07:16 PM
sgm250
Mar 30, 2009 01:17 PM
maniax
Aug 2, 2006 05:58 PM
