tail light warning light
Old Dec 16, 2014 | 11:51 AM
ergoproxy1's Avatar
ergoproxy1
Default tail light warning light
Hey guys. My jzz31 soarer has a tail light warning light on.. all my lights are working fine and my fuses are fine aswell.. ??? Recently changed to after market tail lights too.. and last thing it only comes on after about 10 mins of driving.. if i turn the car off and start it again the light is off but then comes back on
Old Dec 16, 2014 | 12:33 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Reset the ECU and see if it comes back.
Old Dec 16, 2014 | 12:36 PM
GISguy's Avatar
GISguy
Maybe your aftermarket light kit has LEDs? LEDs use far less wattage and the car notices that and thinks the bulbs are out. To fix that, you need to solder in a load resistor in parallel to each LED series.
Old Dec 16, 2014 | 05:16 PM
Studiogeek's Avatar
Studiogeek
My aftermarket, ugly assed tails did the same thing.
Old Dec 17, 2014 | 08:04 AM
Dougspeed's Avatar
Dougspeed
Best solution is to stick the oem set back on there with the proper bulbs. It'll look better too as I have yet to see an aftermarket set that actually look good.
Old May 10, 2021 | 06:13 PM
perfctreig's Avatar
perfctreig
THANK YOU
THANK YOU
THANK YOU!!
I purchased my '99 SC400 in February. The previous owner had put in LED headlights as well as LED taillights. I took out the LED headlights as they were causing issues. I left the LED tails but hated the orange dummy light on the dash.
Followed the instructions and am now free of it. The only thing I'd suggest: The harness is very hard to see and tucked away behind the trunk wall.
Once I pulled it through, I was unable to push the pin back, so I simply cut the wire and put a wire nut on it.
I now have no more dash idiot light.
phillipc1
Jun 4, 2013 10:20 AM
harvfran
Mar 22, 2011 11:48 AM
G_ride
Dec 27, 2010 12:32 PM
JemmyTran
Jul 11, 2008 08:36 PM
Sly1
Lighting
Apr 6, 2005 02:45 AM
