Need help with headlights
Old Mar 8, 2003 | 03:09 PM
mongnata's Avatar
mongnata
Question Need help with headlights
I tried to take the headlights out to clean. However I can't seem to get the headlights out of the car! I took the screws out from the top and it seems to be loosened, but I still can't take it out. The side of the headlight on the outside still seems to be screwed in on each side because it won't really budge and only the inside seems to loosen up. Is there more than one screw to take out? I also can't seem to figure out how to replace the parking lights next to the low beams. The wire there seems to be connected to something other than the bulb.
Old Mar 8, 2003 | 03:38 PM
pcmw's Avatar
pcmw
Use the search function and look under headlight removal. You have not removed the other two headlight nuts. There are diagrams and instructs on the other threads. Thanks
MW
R6Tuan
Jan 26, 2016 05:59 AM
k20trick
IS F (2008-2014)
Dec 7, 2015 10:08 AM
ISf4n
Apr 27, 2011 03:14 PM
Sheehan1p
Jul 14, 2009 06:50 PM
Jmai22
Jul 28, 2002 09:57 PM
