Replaced distributer O Ring and lost timing
Old Nov 6, 2014 | 10:34 AM
PericoSC's Avatar
PericoSC
Default Replaced distributer O Ring and lost timing
So I replaced the distributer oring that was causing oil to leak onto my alternator. I thought everything was smooth until I tried to start it, car got about one crank then completely lost power. My obvious guess is that I lost the timing but i don't think it would cause the car to have a complete loss of power would it? I can't even put my windows up and its a brand new battery. Maybe a fuse or a relay. If anybody can give me some advice so I can start trouble shooting I would greatly appreciate it.
Old Nov 6, 2014 | 01:11 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
try jumping off a running car. its easy to loose the timing when you take the distributor out, its probably off and might start rough but shouldn't kill the battery. sometimes new batteries have been sitting for a while maybe charge it up and try again or jumping it should do the trick, make sure the other car is on and running.
Old Nov 11, 2014 | 05:02 PM
Rhoderman's Avatar
Rhoderman
Check your battery connections. Pull them off and clean them.
If it tried to start once, most likely things are good.
Timing will not cause a loss of DC electrical power (assuming that's what you mean).
Old Nov 12, 2014 | 01:12 PM
PericoSC's Avatar
PericoSC
I just replaced all of the main fusable links and also checked all of the fuses in the kick panel and nothing....car still has no power at all...battery terminals are good too
Old Nov 14, 2014 | 11:49 AM
PericoSC's Avatar
PericoSC
So I just ran my own ground from the battery to the body. I put the key in and the car had power, the radio and lights came on. I went to turn the car on and it just died as soon as the key turned to start and again lost all power. I moved the ground to another spot and it did the same thing. Moved it to another spot and it didnt get any power again.
Old Nov 16, 2014 | 11:38 PM
PericoSC's Avatar
PericoSC
Does anybody has any ideas or suggestions...even basic
Old Nov 17, 2014 | 01:39 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
did you get oil on the alternator, check the plug maybe clean it out sounds like some kind of intermittent short or grounding problem if it works sometimes with another ground..
IS_Sunny
Oct 11, 2021 03:13 PM
coacheddie
Jan 27, 2020 06:29 AM
thomasjti
Nov 18, 2016 06:31 AM
UpstateLex
Nov 9, 2009 11:26 AM
pardesi
Performance
91
Feb 12, 2007 11:28 AM
