Need advice on adjusting clutch
Old Sep 3, 2014 | 02:23 PM
187's Avatar
187
Default Need advice on adjusting clutch
Recently installed a new spec clutch on my sc3. After the clutch was in the biggest thing I noticed is that that pedal is pretty soft compared to the stock clutch I had ( was expecting stiffer). The real problem is that it tried to grab pretty much right off the floor, to the point that it almost doesnt like being put into gear as if it is not fully disengaged.
I actually felt it try and grind going into first at a stop sign because it was say 1/2 an inch off the floor.
I can drive it so long as I go out of my way to depress the clutch more than I am used too.
Looking for someone who had a similar problem, I know there is a rod to adjust the pedal some what so any input on what you did would be great.
Also there is no air in the system and the flywheel was resurfaced.
Old Sep 4, 2014 | 12:31 PM
mecheng10's Avatar
mecheng10
the adjustment rod is attached to the clutch pedal...
it should be self explanatory from there
TGRich
Sep 18, 2013 10:57 AM
pnyboy27
Aug 4, 2008 01:57 AM
minnyminh
Feb 13, 2008 10:53 AM
95 Integra
Dec 13, 2005 07:28 PM
Camshaft
Dec 4, 2002 06:17 PM
