temp won't come on.
Old Jun 21, 2014 | 03:07 AM
skeet92's Avatar
skeet92
Default temp won't come on.
So I just pulled this car out since I brought it in Oct. Realized the air was not coming on when I pressed the bottom. When I to the controller out to be fixed noticed the switch was crappy on the inside. Could it be this needs to be replaced or another problem I should worry about.
Old Jun 21, 2014 | 07:12 PM
jadu's Avatar
jadu
live.love.laugh.lexus
See this thread: https://www.clublexus.com/forums/per...rol-valve.html
I have also lost the heat in my car
Old Jun 23, 2014 | 01:32 AM
skeet92's Avatar
skeet92
Thanks I will check that out today and see what comes about.
Old Jun 24, 2014 | 03:22 PM
skeet92's Avatar
skeet92
So I seen that the cigarette lighter and heat/ac run off the same fuse. Funny things is I just noticed my lighter is not working either. Same article said the fuse was located by the kick panel where there is no fuse box. Just the one under the hood. Does anyone have any idea where this fuse my be located at.
Old Jun 24, 2014 | 03:58 PM
dogwisper's Avatar
dogwisper
There is one by the drivers side kick panel. You have to peel back the carpet from that area. Firmly lift up the carpet and pull it back. 3/4 of the way to the fire wall you will see a little black plastic box marked "fuse". The fuse you want resides inside there. You can see it with your head level with the bottom of the drivers seat. I've spent too much time down there. Have fun.
skeet92
Jun 29, 2014 07:42 AM
primo
RX - 1st Gen (1999-2003)
Apr 1, 2012 08:01 PM
surferdood
Sep 16, 2011 11:42 PM
jsyjordan
Aug 29, 2008 06:45 AM
t70 supra
Sep 17, 2007 10:10 AM
