Fuel Pump Not Getting Power
Old Jun 11, 2014 | 08:54 AM
Trucho's Avatar
Trucho
Default Fuel Pump Not Getting Power
I recently had issues with my car stalling/stuttering so I decided to do 12V fuel pump mod (bypass fuel pump ECU) and car ran like a champ. Then a month after that I had issues getting the car to start up but after multiple attempts the car started up and drove fine. But one morning I went to drive it and the car would crank over and over but no start. My first thought was that the old fuel pump died out since it was getting full 12V and was maybe on its last legs. So I bought a new fuel pump installed and still same issue. I did not hear the fuel pump turning on at all so I tried swapping the EFI relay and still nothing. So then I tried jumping FP and B+ then try starting and nada. Once more I still have not heard fuel pump turn on at any point. So then I tested with multimeter and I do not get any power to FP or +B at all. So then I tried checking power to the wires I crimped together for the 12V fuel pump mod (green and black/red wires) and still no power with key in ON position. I also made sure the main fuse box was getting sufficient power.
Sooooo I am stumped. Is there anything I can test out to see why I am not getting power to fuel pump? I'm not sure if I can test the actual power source of the EFI relay itself or does jumping the FP and B+ bypass the relay?
Thanks guys!
Old Jun 11, 2014 | 09:09 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I don;t think that jumping it bypasses the relay. likely you lost power to that whole part of the circuit. maybe a relay or a large fuse in the engine bay.
Old Jun 11, 2014 | 04:54 PM
Trucho's Avatar
Trucho
Idk of any other fuses that would impact the fuel pump.
Trucho
Jan 1, 2021 01:29 PM
Desacatao
Mar 3, 2019 03:09 PM
Silgs300
Oct 15, 2017 06:38 AM
SC300_704
Nov 12, 2012 06:51 PM
epicaudio
Sep 1, 2010 07:18 PM
