Need Help. Strange symptoms
Old May 9, 2014 | 07:11 AM
Bankswood's Avatar
Bankswood
Default Need Help. Strange symptoms
Hey guys. This has just started happening. I have a 93 SC400. I go to start the car and everything goes dead. Dash lights go out (except for the needles), the clock and the tripometer reset. Car just sits there dead. However if I try to crank it again and I leave the key in the on position the car seems to regain power (almost like it is charging back up) and come back to life. The dash lights come back on and the car starts right up.
Any ideas? Maybe the ecu going out?
Old May 9, 2014 | 09:39 AM
glex4's Avatar
glex4
I'm no expert, but I would check all the fuses. My situation wasn't quite the same, but hey, never know.
Old May 9, 2014 | 12:33 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
check your ground and battery positive cable and make sure they are on tight and not corroded.
Old May 9, 2014 | 01:53 PM
Vrank's Avatar
Vrank
^ this. The cables will actually corrode a good ways down the cable underneath the sheathing over time and may need to be replaced. I'd start with the ground cable
Old May 9, 2014 | 03:12 PM
Bankswood's Avatar
Bankswood
AliSC and Vrank you guys are right. Found a short in the ground. All is well now.
Thanks for the help!
swat1727
Jun 25, 2017 07:32 PM
wwmustang
Apr 8, 2007 09:06 PM
chabelo31
Apr 10, 2006 07:53 PM
technol
Nov 3, 2003 02:49 PM
mjames08
Maintenance
Sep 10, 2003 03:44 AM
