camber question with tein's
Old Feb 10, 2003 | 09:39 PM
g_lex_6's Avatar
g_lex_6
Default camber question with tein's
my tein ha's will be in this friday and i wanted to know the maximum drop without having to replace the camber plates. thanks
Old Feb 10, 2003 | 09:48 PM
pcmw's Avatar
pcmw
"replace the camber plates"
What does that mean?
MW
Old Feb 10, 2003 | 09:56 PM
g_lex_6's Avatar
g_lex_6
im not exactly sure either. that is what i was told by a friend. he said that if you drop a car over a certain amount it will not be able to be adjusted back to its proper alignment.
Old Feb 10, 2003 | 10:13 PM
pcmw's Avatar
pcmw
Okay,
Yeah, that is a camber kit. They do not make one for the SC....yet. Doublewhoosh is designing one now. Hopefully if enough of us commit to buying the kit at ~$180 he will make it a priority. When you lower your car the wheels butterfly. That is what causes the obvious inside track wear. Your SC comes with an adjustment to that camber problem but does not allow very much variance. A camber kit allows for more camber movement to correct the problem of lowering your car.
MW
Old Feb 22, 2003 | 10:46 PM
g_lex_6's Avatar
g_lex_6
my tein ha's just came in yesterday and i am planning on installing them tomorrow. ..how bad will the "butterfly" be if i do about 1.5" all the way around? will it be really niticeable? i am probably going to get the alignment adjusted as much as possible. thanks
Old Feb 23, 2003 | 11:35 AM
MartelJF's Avatar
MartelJF
Second that...
What is the lowest one can go without seriously jeopardizing tire wear, without a proper camber kit?
pwrusr
Suspension
Jul 30, 2012 06:40 AM
ekrebs
Jan 15, 2009 06:51 AM
punch10
Suspension and Brakes
Sep 14, 2006 09:36 AM
STR8-UP-G
15
Jun 17, 2005 01:48 PM
raul
IS - 1st Gen (2001-2005)
Nov 8, 2001 04:00 PM
