Diff ??
Old Mar 18, 2014 | 11:45 AM
Bankswood's Avatar
Bankswood
Default Diff ??
I have a 1993 SC 400. It has the original diff. I can't get the fill plug out. Is the diff case aluminum or steel. I don't want to put a torch on it if it's aluminum.
Old Mar 18, 2014 | 01:13 PM
mecheng10's Avatar
mecheng10
heat should be the last resort!
have you tried using a big breaker bar and cheater pipe yet?
pb blast that little *********** to hell
hold a magnet to it. if it sticks, it is steel
if it doesn't its aluminum!
Old Mar 18, 2014 | 01:43 PM
INTIMAZY's Avatar
INTIMAZY
It's cast iron by the lower passenger side drain plug. The rear cover is aluminum.
FIRE AWAY!
Old Mar 18, 2014 | 03:04 PM
hmhatch's Avatar
hmhatch
Usually ill air chisel them loose if the plug becomes stripped out. Just have to be careful.
Old Mar 19, 2014 | 10:40 PM
oldManTan's Avatar
oldManTan
does anyone here have a TT torsen diff? if you do, what oil do you put in it? i think mine leaked a little and i wanna change the oil in it. thanks
v8sedan
IS F (2008-2014)
13
May 26, 2019 03:00 PM
carguy07
RX - 1st Gen (1999-2003)
Dec 15, 2007 11:36 AM
jezza
Aug 26, 2006 09:31 AM
Grumpa72
Jan 29, 2006 05:13 PM
jacobking
Jan 14, 2005 01:27 PM
