Trac light and cel help
Old Feb 19, 2014 | 11:08 PM
moneysc400's Avatar
moneysc400
Default Trac light and cel help
So I cleaned my mass airflow sensor and trac light and cel came on any body know why?
Old Feb 20, 2014 | 06:48 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
What year is your SC? 92-94 has an AFM that cannot be cleaned with the standard spray cleaner liquid. If done, the MAF is killed. Your AFM could be Karmen Vortex hot wire type. Did you use any sprays to clean it?
Old Feb 24, 2014 | 10:45 PM
moneysc400's Avatar
moneysc400
It's a 95 and the lights went off the next day.
Old Feb 25, 2014 | 10:41 PM
moneysc400's Avatar
moneysc400
Ok I've read tons of threads and got way to many diff possible fixes I was wondering if you have had this prob around 2000 rpm it studers and loses power but regains and not all the time some days runs without a hitch also a few times at a stop light car in park Rpms drop then go back up several times put in nutral and stops any clue what's going on here and possible fixes. Thanks
Old Feb 26, 2014 | 07:04 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Could be a lot of things. Failing ignition coils, AFM, TPS that needs calibration, o2 sensors are a possibility. ECU is definitely not out of the question.
f22s2k
IS F (2008-2014)
Oct 5, 2013 11:06 PM
ttran1999
Oct 19, 2010 08:54 PM
UNOHOO
IS - 1st Gen (2001-2005)
Aug 5, 2009 11:41 AM
fatboyq
Nov 29, 2006 10:15 PM
slash
14
Nov 17, 2004 01:16 PM
