BC Small Core 272 JZ Cams. Need Help.
So my buddy has a set of Brian Crower Small Core 272 Cams from the group buy a while back and is deciding not to use them in his build anymore. I just put together an HX35 single kit on my 1JZ soarer last winter and this winter, i'm currently building to handle the power and this set has come across the board so i'm thinking of jumping on it but i just wanted to make sure they will fit and work in my 1JZ
Now while looking at the cams i noticed that they have 2JZ stamped on them and from what i've heard, these 2JZ cams will fit in my 1JZ with a slight machining. Is this true? Also is there anyway to identify these small core 272 cams to confirm they are actually the correct ones?
Helpful tips and suggestions are much appreciated.
Just buy the correct camshaft that's made for you engine, why go through machining when you can buy the drop ins and be done.
And that Turbo will no flow really well with those cams.
Why is it that all you 1jz guys always want to run a 272 cam in a street car with truck turbos and what I assume to be otherwise stock heads.
These cams do not shine in a stock head with small turbos that don't have the cfm to feed them they also will give you idle issues, low vacuum pressure, and pending on the brand of 272 could present with interference concerns.
272 cams in a 1j under 700 hp with stock rpms is absolutely useless all these cams do is slide your powerband to the right and make it virtually useless in a basic stock configuration JZ 1 or 2.
The ideal street cam for these cars is a 264 with the ideal turbo's being in the 62-67 mm area with A/R's of between a .68 - .91 pending stick or auto and the right supporting fuel upgrades, intercoolers and plumbing!
^^^ Thank You.
And one thing i don't get all of these 1jz guys wanna HX35 etc or whatever and make power, seems like nobody wants to spend the money on a nice decent Turbo /Correct size turbo to make some power.
Everyone wants to make power on the 600whp on the budget..
272 needs dual springs, retainers and billet tensioner.
This is even worse. He341/351 and hy35 all flow about the same or more than the hx on the compressor side, but have a smaller exh housing than the hx which makes it choke harder. Stock cams and holset is a kick *** combination for 350-450whp. Super kick ***. You want 500 go t4 something or other, or large housing t3.
For the OP to drool over. 264 BC cams stock internals C16 still running as a daily today.
Sorry to the 3 Mods for posting this vid everytime this 1jz what cam?,can I make hp?,what size turbo?, r154 power capacity question comes up!!!!!!
I live in Canada so the options for tuning shops or any performance shop at that is hard to come by. That being said my knowledge is limited to the forums mostly for my first questions on topics like this one. So pardon me for asking what seemed to be a stupid question from your reaction but i gotta ask someone right? I want to hear from guys like you with experience and that have done these builds but the ignorance and generalization of a noob gets old.
I finally got a hold of my tuner from another city. He informed me about the low end power loss, vacuum issues, powerband shift, etc. For my application and what my goals are I'm deciding not to go with these cams so don't worry.
^^^ Thank You.
But I'm a 22 year old student so i'm sorry that i don't have thousands of dollars to spend on my car right now? I'm doing this car on a budget sure but i'm not cutting corners everywhere. Yeah sure HX35 with full driftmotion manifold and plumbing isn't up to par with the amount of money i'm apparently supposed to spend but with my very crucial things like internal engine components, cooling, fuel system, ECU and what not i did not cut any corners in fact i spent enough money to maybe be acceptable in your guys' eyes. Suprising i know but I Know where i can and where i can not cut corners. I've spent enough money on Rims, Audio and Body already and i'm just starting with the engine now so give me some time to build something on a budget and get some experience before i start putting tens of thousands of dollars in an engine without the experience and watch all my money go down the drain.
Thanks for the information though either way.
Thanks, i'm leaning towards that now lol.
I think if you had stated your research first and about the large small cores and that you already had some understanding you may have gotten a more positive response, but it looks like either way they are not even remotely suitable for your application, and I think they were just trying to drive that home for the next person who reads it and still decides they want to go 272 cause its a good deal or readily available. Unless you have large everything else, you can't expect large cam's to give you a balanced setup really, the powerband will take a hit. Quick is thinking 600hp because you wouldn't use those cams on lower power applications, the whole power band thing again would not be fun.
cams turbo intake exhaust are all linked, the bigger you go in one area the other areas should also to compliment them. There is a balance!!
OP, Sorry you got your feelings hurt by my comment, but just remember that this is not a PM this is an open forum with lots of ????? consistently being asked about the same or similar things these forums are riddled in 1JZ hp, ability, turbo size, cam selection, injector sizing questions and it just gets OLD.
So my response is directed at all readers not you (soloed) out to try to finally get these ???? answered for everybody to read!!!!!!
