Codes 21,24,61
Old Sep 2, 2013 | 03:18 PM
Brianmoss's Avatar
Brianmoss
Default Codes 21,24,61
Does anyone know what this means?
Old Sep 3, 2013 | 09:52 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
That's what the search button is for.
21= Main o2S and heater signal
24= IAT signal
61=Doesn't exist in the SC400 code list, but I've read it might be something to do with tach or speedo errors...
Old Sep 3, 2013 | 09:54 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Boom. Beat me to it.
Old Sep 3, 2013 | 10:26 AM
Brianmoss's Avatar
Brianmoss
24= IAT signal
I did search and nothing came up thats why i posted. By main o2 do you mean the down stream sensor after the cat or is it one of the two on the manifold that are my upstream ones? I went to auto zone and they don't carry any IAT sensors so do I need to go to Lexus? I have a sc300 so would that make a difference with my code 61?
Thanks.
Old Sep 3, 2013 | 11:24 AM
Brianmoss's Avatar
Brianmoss
I just sent video to 2 other members via text and they also confirmed that it's showing code 61.
Old Sep 3, 2013 | 01:21 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
https://www.clublexus.com/forums/mai...code-21-a.html
Yeah, was saying that the code isn't included in the code lists around these forums.
Old Sep 3, 2013 | 02:57 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
the IAT is built into the maf.
Old Sep 3, 2013 | 06:54 PM
Brianmoss's Avatar
Brianmoss
Code 61 is #2 speed sensor located at the rear of the transmission.
Old Sep 14, 2013 | 01:42 PM
Brianmoss's Avatar
Brianmoss
So I replaced the speed sensor and reset the ecu and 5 min later blinking OD light. Still have code 61 does anyone know why it's still showing my code even after I replaced it.
Old Sep 14, 2013 | 02:59 PM
Vrank's Avatar
Vrank
Ecu could be going bad. Only takes like 15 minutes to pop it open and look at it. Small amount of time to save hair pulling sometimes.
Old Sep 14, 2013 | 03:25 PM
Brianmoss's Avatar
Brianmoss
I just purchased a rebuilt ecu last month so I'd hope that it wouldn't have gone bad already.
Old Sep 15, 2013 | 08:42 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
I heard code 61 could also be a bad shift solenoid. Based off of another thread, if your trans feels a little rough.
Old Sep 15, 2013 | 09:41 AM
Brianmoss's Avatar
Brianmoss
Code 62, 63 and 64 are the solenoids.
Old Sep 18, 2013 | 11:00 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
Did you replace the right speed sensor?
Transmission OBDI Diagnostic Codes
42 - No. 1 speed sensor signal malfunction
46 - Open or short circuit in no. 4 solenoid valve
61 - No. 2 speed sensor signal malfunction
62 - Open or short circuit in no. 1 solenoid valve
63 - Open or short circuit in no. 2 solenoid valve
64 - Open or short circuit in no. 3 solenoid valve
67 - OD direct clutch speed sensor signal malfunction
68 - Short circuit in kick-down switch
Old Sep 18, 2013 | 04:59 PM
Brianmoss's Avatar
Brianmoss
