2JZGTE rebuild
Subscribe
Aug 23, 2013 | 02:06 PM
  #61
Sandblasted my intake manifold...
Before
After
USDM 550
Reply 0
Aug 23, 2013 | 02:10 PM
  #62
That sandblasting job looks great! Looks like I'll be having some fun w/ the sandblaster myself soon. Great build, keep up the good work!
Reply 0
Aug 23, 2013 | 02:11 PM
  #63
Quote: That sandblasting job looks great! Looks like I'll be having some fun w/ the sandblaster myself soon. Great build, keep up the good work!
I paid someone to do the job, i would do it myself if I have the tools.
Reply 0
Aug 23, 2013 | 02:18 PM
  #64
Quote: I paid someone to do the job, i would do it myself if I have the tools.
All the better! Less work on non-essential tasks. Thanks for being so detailed in your build! I'm going through the exact same part of my build w/ the head work and water / oil pump installation this week.
Reply 0
Aug 23, 2013 | 02:21 PM
  #65
Quote: All the better! Less work on non-essential tasks. Thanks for being so detailed in your build! I'm going through the exact same part of my build w/ the head work and water / oil pump installation this week.
Get new oil pump..
Reply 0
Aug 23, 2013 | 02:23 PM
  #66
Quote: Get new oil pump..
My boy @ work has been stressing this for the past two weeks. Now when you say new, you mean brand spanking new, or used lower mileage? My old one had 240k on it so it definitely has to go.
Reply 0
Aug 23, 2013 | 02:26 PM
  #67
Your project is looking great, but I have a couple questions.
First, did you check for wrist pin movement before reusing your pistons? When I rebuilt my 2JZ, most of the pistons were worn beyond the service limit. The way to tell is to try to move the wrist pin within the piston at room temp. If it moves within the piston, the piston needs to be replaced. The wrist pins should be an interference fit at room temp and require piston heating to install.
Regarding your valve clearances, they are likely tight due to the valve job. Even though the stems were machined, they are probably still slightly high due to cutting the seats and grinding the valves.
Reply 0
Aug 23, 2013 | 02:28 PM
  #68
Quote: My boy @ work has been stressing this for the past two weeks. Now when you say new, you mean brand spanking new, or used lower mileage? My old one had 240k on it so it definitely has to go.
You have to get an OE brand new. Lots of guys here have nightmares not changing them.
Talking about pulling the engine out of the car again and taking everything apart.
I would not trust a used one unless you brought it new and ran it yourself. Most of these engines have been sitting for a while.
$160 at Elmhurst and you are good to go.
Reply 0
Aug 23, 2013 | 02:32 PM
  #69
Quote: Your project is looking great, but I have a couple questions.
I did not take the pistons and rods apart so I do not know. I may have to look at that again.
And as for the valve clearance, I have to go thinner shims. Yes I believe it was the valve job. I bought 20 shims and they are $7 per piece. Holy %&^!!
Reply 0
Aug 23, 2013 | 02:37 PM
  #70
stockhatch, did yours go bad?
Reply 0
Aug 23, 2013 | 03:08 PM
  #71
Man, did the intake manifold come out great or what???
Looks great!!!!
Reply 0
Aug 23, 2013 | 03:10 PM
  #72
Quote: Man, did the intake manifold come out great or what???
Looks great!!!!
Thanks man, I wanted it chromed though, too much work I think.
Reply 0
Aug 23, 2013 | 03:15 PM
  #73
I like the look of chrome under any hood, when done properly and in moderation. I think chrome just says clean and clean means time well spent under the hood and done right. Jmo.
Reply 0
Aug 23, 2013 | 03:18 PM
  #74
Quote: Thanks man, I wanted it chromed though, too much work I think.
Polishing the intae manifold, TB, valve covers and turbo compressor housing cost me $450.00 locally.
Reply 0
Aug 23, 2013 | 03:27 PM
  #75
Quote: Polishing the intae manifold, TB, valve covers and turbo compressor housing cost me $450.00 locally.
Where? Basko did the sandblasting...
Did you do all the intake manifold or just the upper plenum?
Reply 0
