Detonating...Help!
You need to remove the Fuel damper under the intake in front of the starter and make the fuel feed that goes into that go to the fuel rail and you need a FPR to see you fuel pressure at boost the stock reg will not add at 1:1 = 1 psi of boost 1 psi fuel pressure increase also recommend doing the fuel pump mod so it runs at 12+volts all the time instead of ramping.
Your tuning the CAR BLIND CAUSE YOU DON'T KNOW WHERE YOUR FUEL PRESSURE IS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Well guess i mis read or it was edited in as you were quoting " I see guys on stock compression making more power" and im wondering where you see this so frequently?
and led me to believe you were using that as a point of reference for your build....
..... so either way your comp is fine.
I run 14 psi on a bb 60-1 all day (and formerly a 67) with no detonation, What exact plugs are you running. Its better to know exactly what you have... not "oh it was something"
also what fuel pump are you running?
Aeromotive 340lph
Thank you for the advise. I plan on doing this as soon as possible. Will I need additional fuel lines to bypass the damper, or can I get away with what is already there? Is the fuel pump mod where I bypass that controller thing in the rear interior panel or are you referring to something else?
The Aeromotive A1000-6 Injected Bypass Regulator was developed for high-horsepower fuel injected applications. Compatible with Aeromotive's A1000 Fuel Pump, this regulator is cousin to the widely-used A1000 Injected Bypass Regulator, delivering performance, long life & reliability.
Base pressure adjustable from 30-70 psi
CNC-machined from 6061 T6 billet aluminum
(2) ORB-06 inlet ports and (1) ORB-06 return ports and 1/8" NPT gauge port
Fuel pressure rises on 1:1 ratio when referencing boost
Alcohol compatible
Fuel damper pic below
http://t1.gstatic.com/images?q=tbn:A...iGtI4RE3LooAmA
Another pic.
http://www.villagetoyotaparts.com/im...ze/MAG517F.jpg
Hope this helps!!!!
You will need a additional fuel line to get to the rail and yes the by pass is located in the driver side rear panel above the rear seat bottom, and get a FPR that does 1:1 ratio most common is the Aeromotive below is the basics.
Alcohol compatible
Another pic.
Hope this helps!!!!
Alcohol compatible
Another pic.
Hope this helps!!!!
So if the diphragm-actuated 2jz FPR doesn't do 1/1, whats the vacuum line for?
AFPR, WBo2, and Boost control should be the most basic way of making adjustments to a turbo system, so get those stat.
With 91 octane of various quality around my locale, 86mm piston engines with boost can only muster around 10-14 degrees timing at WOT before preignition.
Check my datalogger thread in my sig to find out how much timing you are really making.
also for the 12v fuel mod, I used to have that but then I put it back to stock and noticed no difference whatsoever on my wideband which is on all the time. the pump is always ramped up by the time I make good boost. I don't think this is the issue, as I believe his issue is the stock ecu and the 550cc inejctors he has thrown on there with the map ecu 3.
OP you need better engine management. start with a standalone or use the GTE ecu. the GE ecu is not a reliable ecu to use for boost, unless you slap the most complicated piggyback on it, and then tune and tune it, and at that point you realize you should have switched ecu's at the start, cause the piggyback setup on the ge ecu will still be far from perfect after all that, whereas with the other routes your car will drive/boost much better.
Forget the MAP ECU, sell it, get a JDM 2jzgte ECU, then read this thread a thousand times in a row:
https://www.clublexus.com/forums/sc-...t-ecu-mod.html
Blk&blu, you made some interesting points and its rare that I disagree with you but the stock fuel pressure regulator is a 1:1 unit as the top diaphragm is vac/boost referenced factory. I have not removed the dampner either and at his power levels it is not needed, althouth its a good idea to remove the dampener going for more than 500, but this shouldn't be the problem I run more boost than that with no issues whatsoever, on a completely factory fuel system except for injectors.
Yeah, he shouldn't be having any issues at all engine wise or fuel capacity wise, I would have to say this is probably an issue in the map ecu 3 that needs to be sorted out. they can be touchy, and especially with the amount of fuel (maf signal) he probably has to pull (decrease) to make those 550cc injectors work right at full boost, it is probably jumping up the timing quite a bit as the ecu registered less load, and then the ecu is probably trying to suddenly pull timing in boost when it knocks, which will happen over and over.
That being said and to answer your second question, you can run most any piggyback just fine on the GTE ecu. The problem in your setup is the GE ecu, not the piggyback, and if you do go with the JDM map sensor gte ecu then you probably want to sell your map ecu 3 and get a safc 1 or 2 or something similar that works with the jdm ecu.
the JDM 2jzgte ecu's (the ones most use) control 440's perfect, and they even control 550's fine as long as you have the o2 sensor hooked up but may run a little rich. With the JDM gte ecu, you do not need the map ecu 3 at all, in fact it is redundant because the JDM ecu already uses a map sensor, and you really just need a simple afc device like a safc for 550's or 660's.
You have a couple options either
Get a better tuner to tune that map ecu.
Sell it and get a an aristo ecu with safc or whatever piggyback your tuner feels comfortable with.
Buy an aem v1 or v2.
Or whatever standalone your tuner can tune..
That's what I would do if I were you.
GL
GL
