Auto shifting BOV-like noise
Old Jul 11, 2013 | 11:10 AM
96shox's Avatar
96shox
Default Auto shifting BOV-like noise
Searched extensively online and on CL with no similar issue.
1)I just got a '99 SC300, 86k miles, automatic. Well maintained, fluid flushed at dealer ~60k (even though i found it to be overfilled by about 2inches on the dipstick when hot). I noticed that ONLY under hard acceleration when it shifts 1-2 and 2-3, right as it shifts there is a faint noise, almost like a BOV (no turbo jokes ); or like a chain rattle. No physical rattle or shake, but just a very faint noise. Any idea how to diagnose?
Might as well throw this out too so i dont make a another thread
2) Power Steering was done at dealer too about 20k miles ago, but the fluid looks like motor oil color (clean) instead of ATF red. What should I top it off with? ATF or PS Fluid?
Old Jul 11, 2013 | 12:21 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
1) get under the car and look for loose things and hope is not the trans.
2) should be red technically the best is to drain and refill with ATF, but some people do just use power steering fluid not really sure of the long term effects of that if your power steering is working fine just top it off if you have issues I would drain + refill with atf.
3) are you talking about an HID, thats the only time I have ever noticed it and not much you can do about it but trim the tabs on the bulb so you can fit it in at a different angle. some of the tabs are long and short, if you make them all short you can probably get it in there at 3 different angles total, but not sure how well it will stay in place after that, maybe try with an old test bulb I wouldn't attempt it the first time on an nice bulb.
Old Jul 12, 2013 | 10:41 AM
96shox's Avatar
96shox
Thanks,
I didnt find anything loose under the car; from what I can tell, the sound comes from the tranny. Im just wondering if thats a sign of slipage or whatever, because I cant find anyone else talking about that type of noise on an upshift.
Old Jul 13, 2013 | 12:26 PM
96shox's Avatar
96shox
Bump,
So no one has ever heard of a auto tranny making a noise on upshift?
D-Boi
Nov 22, 2010 12:12 PM
trips1
RX - 1st Gen (1999-2003)
Sep 13, 2009 07:15 AM
planetommy
Oct 17, 2006 12:13 PM
MoogieBoogie
Aug 4, 2006 07:39 PM
Gs L-tune
Mar 29, 2006 05:28 AM
