CatManD3W SC300 Ongoing Build...
Old Aug 1, 2016 | 12:50 PM
  #811
CatManD3W's Avatar
CatManD3W
Finished off the rear TT calipers with Lexus script Logo.....awaiting rotors to arrive which should be today to start installing it all..
Old Aug 1, 2016 | 09:26 PM
  #812
CatManD3W's Avatar
CatManD3W
Got some work done on the car tonight.....managed to get the passenger rear all finished up.....
Comparison of OEM SC300 and TT Rotors.
Goodridge line installed and checking clearances with wheels and suspension.
Right rear completed.....
Old Aug 3, 2016 | 04:43 PM
  #813
CatManD3W's Avatar
CatManD3W
Finalized my design for brake ducts....Just need to get the 2 pieces welded together and some bolts on back side....
Dont mind the busted up and cracked lip/bumper.......
Old Aug 3, 2016 | 05:50 PM
  #814
97-SC300's Avatar
97-SC300
Sick man!
I was thinking of adding some type of ducting to the passenger side that would route air from the foglight opening up into the airbox for the engine. Any ideas on what you will use for the duct?
Roman
Old Aug 3, 2016 | 07:06 PM
  #815
CatManD3W's Avatar
CatManD3W
Originally Posted by 97-SC300
Sick man!
Roman
Just simply brake ducting from Jegs or Summit.....3" x 11ft is usually what you get to do both sides
Old Aug 4, 2016 | 05:58 AM
  #816
tjmhillz's Avatar
tjmhillz
Looking good man.. Once you finish them are you going to paint match them?
Old Aug 4, 2016 | 08:22 AM
  #817
CatManD3W's Avatar
CatManD3W
Probably not....may just leave it in raw from for now....if I were to do anything powdercoat would be the only thing to consider.......
Old Aug 4, 2016 | 10:36 AM
  #818
Blkexcoupe's Avatar
Blkexcoupe
to your build. The brake ducting is really cool.
Would 3 inch have clearance issues at full lock with wide wheels in the front? Are you planning on fabricating a vented shield to direct the air to the rotor or just place the ducting hose on to the rotor?
Old Aug 4, 2016 | 11:33 AM
  #819
CatManD3W's Avatar
CatManD3W
3" should plenty of clearance.....also it is pretty rare to have your car at full lock on the track...
Depending on how it works out I may just direct the air to be directed towards rotors....the most optimal way to cool is to add the vented shield you mentioned....at some point im sure I will go that route.
Old Aug 4, 2016 | 06:03 PM
  #820
Blkexcoupe's Avatar
Blkexcoupe
That is true. I would just be worried about rubbing on the hose while going up and down driveways, but I guess that concern would vary based on the area you live and how often you would need to turn full lock.
Old Aug 12, 2016 | 10:45 AM
  #821
CatManD3W's Avatar
CatManD3W
Completed both sides for brake ducts.....getting them welded today...
I also have enough material to make 3 more sets if anyone is interested please PM me.
Old Aug 12, 2016 | 02:42 PM
  #822
lilSCsteve's Avatar
lilSCsteve
Ryan, nice duct work...I like your ideas!
Old Aug 15, 2016 | 05:13 PM
  #823
CatManD3W's Avatar
CatManD3W
Thanks guys at welder this week....parts ordered from Summit..
So later this week should be putting it all together...
Old Aug 15, 2016 | 06:18 PM
  #824
97-SC300's Avatar
97-SC300
Very nice work man!
Old Aug 16, 2016 | 06:33 AM
  #825
Halon's Avatar
Halon
Looking good man. I'd totally snag a set from you, but I literally have so many parts laying around that still need to be installed, last thing I need is more! Maybe in the future though.
