CatManD3W SC300 Ongoing Build...
nice find, I much prefer the manual ecu now just seems to jive that much better with the manual transmission, also the map ecu and patch harness makes things nice and easy. good luck let us know how those 850's go on the jdm ecu, should be interesting.
Thanks....
oh yeah I would grab a mbc pronto. even when you set it to 14 psi you will gain a bunch of power cause it keeps the wastegate from creeping open early. electronic is good/fun but they are quite picky at times.
I personally run a Hallman Pro
http://www.maperformance.com/hallman...ontroller.html
Forge makes on for a really good price, and reviews of it are top notch. It's what I'd probably buy if I was in the market right now
http://www.maperformance.com/forge-m...r-fmbv050.html
GrimmSpeed is local to me as well, they make good stuff
http://www.maperformance.com/grimmsp...universal.html
But there are literally hundreds of different ones you can select from, and you can't go wrong unless you buy some janky cheapo unit of egay.
http://www.maperformance.com/boost-controllers/
http://forums.evolutionm.net/evo-eng...ed-tuning.html
Hopefully it's ok to post links to that site. I'm not affiliated with them, order from wherever the hell you want.
