air conditioner intakes
Not sure were the intakes are but I used Wurth new car scent for my car it was pretty easy. Search it on ebay cost me about $20. Guessing you can use the same method for lysol.
Directions for use are:
To use Wurth Quick Fresh New Car Scent, roll up all the windows and turn the engine on. Turn the air conditioner and fan on maximum and turn on the air re-circulate button (it usually shows a little arrow traveling in a circle within an outline of a car). Place the can of Quick Fresh on the floor of your vehicle and press the button to release the fogging spray. Close the doors and wait ten minutes.As the can empties, the fog will circulate through the vehicle's AC system and passenger cabin. You should not be inside the car at this time. When ten minutes is up, open all the doors and let the air out. Initially, the scent will be strong inside the vehicle.If you can, allow it to sit with the windows down overnight or for several hours. Driving with the windows down will also help the scent fade.
