well i got another ecu and my car still wont start this beast killing me no cracking and fuel pump doesn't come on with key
if i bypass fuel pump ecu pump works fine with key
if i by pass start relay under hood starter wants to crank over
stuff i got into it
New starter
New used ECU (since my had bad caps)
Check wiring harness on motor it fine
NEw starter relay
check all fuses all look good and swapped with new on few for starting stuff just in case
So you're saying when you bypass the fuel pump ECU, the pump works, but when you don't bypass the fuel pump ECU, it doesn't work? If this is the case, then it's your fuel ECU, unless that is what you just replaced...
