Shakey Idle ??? Car Performs Fine
Old May 3, 2013 | 11:30 AM
ScWift92's Avatar
ScWift92
Exclamation Shakey Idle ??? Car Performs Fine
Hey Club Lexus,
My Car Is Idling at a normal idle speed 800-850 RPM but shakes roughly like it wants to stall but wont the car SOUNDS CAMMED OUT!
When you give the car gas its fine and it performs fine.
Brand :
Wires
Cap
Rotor
Newer Plugs
Injector O-rings
Can I Get Some Imput ? Any one had this issue?
Old May 3, 2013 | 12:13 PM
ScWift92's Avatar
ScWift92
Also There Is no check engine light and no codes being thrown .
Old May 3, 2013 | 01:14 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
There is a great DIY for bucking, hesitation and erratic idle on here. Use the search button, it will come up. I say its the IACV, TPS, or MAF sensor, or a combo of the three. Also try cleaning your throttle body with some great cleaner and a wire tooth brush.
Old May 3, 2013 | 01:39 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
^^^ those and add old o2 sensors to the list of possibilities.
Old May 3, 2013 | 01:44 PM
zneubauer's Avatar
zneubauer
I would start with the iacv and clean it with new gaskets then go from there.
Old May 3, 2013 | 02:40 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
also if you removed the distributor make sure your timing is right with the light, easiest way to make a 2jz sound like a boat is to be 1 tooth off in the direction that retards the timing.
Old May 3, 2013 | 06:14 PM
ScWift92's Avatar
ScWift92
i Ordered 2 new 02's and i changed back to my old MAF and it got worse
i noticed when i put my hand over my intake it stopped bogging and ran regular
Old May 3, 2013 | 10:01 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I dont get what you mean by hand over the intake, you mean the filter?
Old May 3, 2013 | 10:42 PM
ScWift92's Avatar
ScWift92
i have a short ram and took of the cone and it started to build on rpm and didnt give me any more problems and i started it 2 hours ago in 55 degree weather and she idled better???
Old May 4, 2013 | 05:57 PM
ScWift92's Avatar
ScWift92
anything ?????
Old May 5, 2013 | 05:01 PM
ScWift92's Avatar
ScWift92
Can I Have Some Suggestions
Old May 5, 2013 | 07:32 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
did you try messing with the tps. mark where it is currently set first then try adjusting it and see if it gets better, if not put it back.
cocopebble
Dec 3, 2017 09:25 PM
that209kid
Jul 12, 2017 09:19 PM
khutch
Nov 28, 2013 01:05 PM
Seize
GS - 1st Gen (1993-1997)
17
Aug 8, 2005 12:08 PM
SCmist
Sep 14, 2003 11:17 PM
