Anyone Have Surging Problems
Old Dec 30, 2002 | 12:03 AM
2Lexus430s's Avatar
2Lexus430s
Default Anyone Have Surging Problems
Does anyone elses (95-96) SC400 Surge a bit around 40mph?
My car surges pretty bad around that speed, generally when it cold, or after driving for a real long time.
Old Dec 30, 2002 | 09:19 AM
LexusBiz's Avatar
LexusBiz
TealLexus,
I'v got the same problem on my 92 SC400. I thought it was the plugs so I changed them out to Bosch Platinum+4. No luck, still have the problem. Was thinking maybe its the wires, or ignition system.
I remember my moms old Maxima (86') had the same exact problem at about 45mph, it turned out to be a bad/miss firing fuel injector. I doubt thats the case with Lexus engines. Anyhow let me know if you find out anything.
Thanks
Biz
Old Dec 30, 2002 | 03:15 PM
SCV8's Avatar
SCV8
These cars have a lock-up type,electronically controlled torque convertor that switches over to lock-up mode at around 40mph.
Pretty sure there's a torque reduction feature in the ECU to save the convertor from abuse at lower speeds,that's why these cars are a bit quicker from 40 up.
The features tend to flutter at that speed,probably wouldn't be noticeable if the tranny was brand new.
Old Dec 30, 2002 | 03:51 PM
rushgator's Avatar
rushgator
I've read elsewhere on this forum that you can reduce the surging with a tranny fluid & filter change. Try higher quality fluid. I believe that the tranny takes Dextron 2. Anyone have any reccomendations for premium fluids?? Changing tranny fluid will not stop the surging entirely. It is just a fact of life with an SC400.
Old Dec 30, 2002 | 04:31 PM
Taka's Avatar
Taka
I had shaking problem around exact 40mph, and after I replaced my o2 sensor, it's fine now. it might be just my issue.
Old Dec 30, 2002 | 04:32 PM
Lvangundy
Guest
Posts: n/a
No dexron!
Toyota Type-IV only. It's the smoothest and safest bet.
Old Dec 30, 2002 | 10:40 PM
2Lexus430s's Avatar
2Lexus430s
I guess I should have posted the things I have already done to combat this problem...
1st- Replaced the Entire Tranny and T/C with a Rebuilt Factory Ordered Lexus Unit ($1800)
Still had the problem
2nd- Replaced the Drive Shaft with a new one from lexus (Included new Center Support Bearing) ($800.00)
3rd- Replaced Spark Plugs (Though it was misfiring)
4th- Replaced O2 Sensor
5th- Replaced Idle Air Controller
Still have the problem..
Yeah.. I'm broke from this little venture..
Old Jan 3, 2003 | 08:08 AM
NRG's Avatar
NRG
um.. i notice i had that problem too. i though it was an O2 sensor.
Old Jan 3, 2003 | 10:40 AM
djl's Avatar
djl
1. Check proper operation of cam sensors (located by distributor caps) and engine speed sensor (located close to oil filter).
2. Verify proper operation of ECU.
3. Verify proper operation of MAF.
Good Luck,
DJL
9Dragnfly2
Jan 11, 2015 05:32 PM
Sc400Jimmy
Apr 16, 2014 07:55 PM
brad11140
Feb 28, 2014 01:10 AM
farva812
Feb 23, 2014 09:10 PM
dre101
May 7, 2012 03:14 PM
