1996 sc300 p0401 code help please!
Old Apr 7, 2013 | 06:22 PM
dozen91's Avatar
dozen91
Default 1996 sc300 p0401 code help please!
I have a 96 sc300 5 speed with about 120k miles.
I have the p0401 insufficient egr flow code.
Recently I did a full tune up cleaned out intake manifold
my throttle body and low to no carbon build up
Egr valve had tons of carbon in it cleaned it out with carb cleaner
vacuum tested egr looks like its working fine
gave it vacuum when car was on no change in idle
As of now i have no idle or any issue car runs great
any help is appreciated im trying to pass CA smog but that cel wont let me :[
Old Apr 7, 2013 | 06:45 PM
Vrank's Avatar
Vrank
take a 1k ohm resistor and stick it into the plug of the sensor responsible for this. might work. I've used that value for egr stuff on an obd2 supra before. can't remember if it was that exact code but the number seems familiar. If it works you might wanna clip the wirea about 3" off the clip, connect the wires with the resistor from where you clipped, use heat shrink or tape over your connection, then tape around that and the clip with pigtail and plug it in to make it look like all is functioning as it should for a visual. good luck.
Old Apr 8, 2013 | 03:53 PM
dozen91's Avatar
dozen91
Iv heard of the resistor trick but doing that wont pass my numbers for me
Im trying to get advice on how to fix this issue
i read it could be the vsv, vacuum modulator, or even carbon inside manifold just dont know how to go about it
took it to a shop they just guessed around and threw prices at me...
mpm86
GS - 1st Gen (1993-1997)
Apr 5, 2014 09:56 PM
PearlESC3
Nov 20, 2012 12:06 PM
SCME87
Aug 25, 2012 10:01 AM
iwannadie
Apr 29, 2011 07:18 PM
fowcbler
Apr 18, 2008 09:48 AM
