weird clunking feeling going over bumps
my sc has prothane lower bushings and whiteline steering rack bushings. i noticed when i go over bumps the car clunks pretty hard. could it be the upper control arms? the car sits on eibachs with blisteins shocks.
Thanks,
Sid
Thanks,
Sid
Can you tell where can you hear it? Front or rear? Check end links, ball joints, bolts that hold the crossmember... There's a detailed thread somewhere, I can't search right now, but you need to retorque the bolts to spec.
Check the center bolt on the steering rack. I had this issue when riding super low with a eibach kyb setup. All of that front camber was causing that center bolt on the steering rack to loosen over time. I hope this helps.
balljoints don't really back out since they have the cotter pin... guessing it could be bad ball joints. sway bar end links are new. going to torque him while i'm down there.
Iparkcars
Suspension and Brakes
Apr 12, 2013 04:02 PM
BoostAddct
Oct 28, 2011 09:29 PM
mtd2198
Jul 1, 2011 07:42 AM
DETUNED
Nov 24, 2004 04:15 PM
