11 mpg????
hey guys so lately i have relized that my sc has been getting really bad gas MPG like about 11 miles per. and i have been scratching my head about it what could it be i dont know to much about the problem. the only things i can come up with are vac lines. my car does run healthy just has a slight exhaust leak any ideas on what it could be?
thank you
thank you
good call on the o2 sensors....reminds me of a potential bad catalytic converter.
As for injectors, I would try some cleaning formula that you dump in your tank before you ever go through the hassle of swapping them out.
[QUOTE=KingPhilip;7800811]Before you go to injectors, check stuck calipers first, then o2 sensors. Pre-OBD2 SC's, don't throw codes when o2 sensors misread.]
i have a 93 and its obd1 how do i kow if the o2 sensors are bad?
[quote=2jzNoshizz;7803053]According to one thread I read, o2 sensors for preOBD2 Is part of maintenance and should be replaced every 80k miles. So I did everything when I had the same gas mileage issues. I used to get around 11-15MPG's.
run car to 1/4 tank take half bottle of seafoam into tank then fill up.. i have a 92 sc400 and im averaging 24 in the cold and close to 30 when warm/hot out.. so ya thers something going on.. what kind of parts did you use when you did the tune up
Well usually a good tuneup will help.
- Check spark plugs
- Check wires
- Check distributor cap and rotor
- emissions removed or working properly ? bad egr can cause issues as well
- Check 02 sensors ( I ran 2 universal bosch sensors on my 93 and it helped with idle and mpg )
- Make sure air filter / maf are both clean ( you can buy the CRC maf cleaner at any local parts store - Advance Auto usually keeps em in stock )
- Check for any other engine related issues.
- Hows your catalytic converter?
- Check stuck brakes including emergency brake
- Bad injectors ? could be stuck open?
How does the car feel driving?
- Check spark plugs
- Check wires
