Sc drift build
Old Mar 8, 2013 | 06:40 PM
  #31
wirelesstj's Avatar
wirelesstj
sweet! open dp right now?
Old Mar 8, 2013 | 06:58 PM
  #32
Uhhhsc300's Avatar
Uhhhsc300
One more please? My plug is broken to the turbo pressure sensor can anyone tell me which wire colors go to which prongs on the plug?
Old Mar 8, 2013 | 07:00 PM
  #33
Uhhhsc300's Avatar
Uhhhsc300
No I have a 3 in exhaust straight pipe. Hopefully it's not too loud but I'm sure it will be lol
Old Mar 9, 2013 | 12:30 AM
  #34
Uhhhsc300's Avatar
Uhhhsc300
Headlight brackets need little finishing touches and tonight I got the diff and driveline in. I got this car in pieces pretty much so putting it together and not having all the hardware sucks. I spent like $50 on hardware just for the diff and driveline. Luckily I had the big front mounting bolts and bushings for the diff.
Old Mar 9, 2013 | 11:07 AM
  #35
MumRah's Avatar
MumRah
do you have any picz on your suspension set up? and are you running modded knouckles and stuff like that
Old Mar 9, 2013 | 04:22 PM
  #36
Uhhhsc300's Avatar
Uhhhsc300
I can take some. I will have knuckles but I don't yet. I also want to make a dual caliper witha hydro ebrake so ill probably play around with that later.
Old Mar 9, 2013 | 04:32 PM
  #37
1sWt2GS's Avatar
1sWt2GS
wow looking good. cant imagine the amount of work you put in!
Old Mar 9, 2013 | 09:13 PM
  #38
Uhhhsc300's Avatar
Uhhhsc300
A lot of late nights. I still can't decide what color to paint it. I'm thinking gunmetal grey
Old Mar 15, 2013 | 11:08 PM
  #39
Uhhhsc300's Avatar
Uhhhsc300
So almost every day I think I'm going to start my car and I find more things to do. Hopefully soon it will at least be running. I did put the diff and do some of the wiring. I gotta put exhaust and sway bars on I really want to drive this car soon.
Old Mar 16, 2013 | 07:05 AM
  #40
2jzcoupe's Avatar
2jzcoupe
I would really like to see the dual caliper hand brake set-up i loved it in my 240 and really want one in my sc.
Old Mar 16, 2013 | 09:39 AM
  #41
MKIVS374's Avatar
MKIVS374
Looks good. What class are you trying to run?
Old Mar 19, 2013 | 10:13 PM
  #42
Uhhhsc300's Avatar
Uhhhsc300
I'm jut building it for drift no class specifically.
I'm tryin I get my car to start and I have all the wiring hooked up and grounded, but I can get power to the ecu. I have 12v at the coil packs, fuel injecters, I just can't seem to power the ecu. I've been looking for a good wiring diagram but I can't find one anywhere
Old Mar 20, 2013 | 08:55 PM
  #43
Uhhhsc300's Avatar
Uhhhsc300
The crank angle sensor had a bad wire, it started and ra good. I shut it off and now it's doing the same thing again it won't start. Lovely
Old Apr 2, 2013 | 06:42 PM
  #44
Uhhhsc300's Avatar
Uhhhsc300
Not much progress. I've been super busy. I mess around with the car I think my ecu is bad so I'm looking for 1 if one of you have a soarer ecu. Or repair them
Old Apr 7, 2013 | 03:14 PM
  #45
Uhhhsc300's Avatar
Uhhhsc300
I picked up a sard ecu and another stock one for $180 from an awesome guy in Canada. So hopefully that will fix my issue we'll see
outlaw0209
Feb 6, 2011 03:23 PM
24boosted
Mar 20, 2010 02:28 PM
sakataj
Mar 19, 2010 06:43 PM
FireCode
Feb 18, 2008 04:10 AM
