1UZ experts, I need help!
Old Feb 24, 2013 | 06:28 PM
MMCtuner's Avatar
MMCtuner
Exclamation 1UZ experts, I need help!
Hi people. I hope someone can help me with this.
I´m installing a F/IC-8 piggyback on my SC400 by following a diagram that another member gave me. All went good til I found that my engine speed sensor (crank) and cam position sensor wires (#5 and 7) were tied together at the ECU.
I need both of them to finish my piggyback install.
What should I do? Is the signal the same in both sensors and I can tie the FIC wires there too?
I just don´t know what to do
Old Feb 24, 2013 | 06:47 PM
99SC42's Avatar
99SC42
No its probably the grounds that are tied together not the signal.
Old Feb 24, 2013 | 07:45 PM
MMCtuner's Avatar
MMCtuner
http://alscforum.com/discus/messages/117/2275.jpg
Not grounds. Number 5 and 7 at the E10 connector.
#5 is attached to the #7 cable.
Old Feb 27, 2013 | 03:04 PM
MMCtuner's Avatar
MMCtuner
Well, yes. Following some diagrams to make sure, you were right Quicksc4
I´ve install everything and today my car started. Awful idling and no more than 2k revs, but it started.
As threads seems can´t be deleted I´ll continue to post my progress with the AEM F/IC-8 install and tuning. Maybe later I can make a build thread and merge them.
Old Feb 27, 2013 | 10:44 PM
mickesanda's Avatar
mickesanda
Default AEM F-IC 8 piggyback
Please continue to post your progress, i was looking to buy the same EMS. Where did you buy it?
Did you get harness so that you can plug it in the OEM ECU? How much did it cost ?
Please post pictures of the install and detailed info on changes that you had to make and so on.
Thx
/Mike
Old Feb 28, 2013 | 07:54 AM
MMCtuner's Avatar
MMCtuner
Bought it a year ago at $537 on eBay. No PnP harness. I´ve follow a diagram that another member gave me.
Old Feb 28, 2013 | 08:15 AM
99SC42's Avatar
99SC42
Yeah because it wouldn't make sense that's what i thought , if they tied the cam and crank signal together it will not work.
The grounds yes it will work they are tied together!
Nice glad you got it working bro!
Old Feb 28, 2013 | 01:20 PM
MMCtuner's Avatar
MMCtuner
Thanks, I´m feeling that the install was the easy part thoe.
This weekend I´ll try to tune it a little to see if I can make it work.
Now if I put the jumper harness my car throws a CEL. Don´t know why :S
Old Feb 28, 2013 | 01:34 PM
99SC42's Avatar
99SC42
Ok it's probably a wire (s) cross around , i am sure the wiring in the jumper harness is not 100% correct there is something missing.
Old Feb 28, 2013 | 02:08 PM
MMCtuner's Avatar
MMCtuner
At first car didn´t start because I had cam and crank sensors in and out reversed. Now that I switch them, my car started with the FIC with a rough idle and firing problems (but started) and when I put the jumper harness it´ll start normally and run fine but after some seconds it throws a CEL.
Old Mar 4, 2013 | 01:47 PM
MMCtuner's Avatar
MMCtuner
Progress!!
First I re-did the wiring and get rid of the CEL (had a cam in/out wrong)
connected the F/IC and, while at high rpm went quite good (just quite), car didn´t idle good. So, rough idle and missfires.
Today I did this http://clubsciontc.com/forums/diy-in...tor-mod-27163/ and...
F/IC working as it should, P-E-R-F-E-C-T!
This week she´ll be at the garage as I´ll go on a trip. As soon as I get back, I´ll tune it a bit and go for a ride!
Videos comming soon
Old Mar 4, 2013 | 02:09 PM
99SC42's Avatar
99SC42
See ^^^ Lol i knew .
Kool man post some pics/video once you get a chance.
Old Mar 4, 2013 | 02:11 PM
MMCtuner's Avatar
MMCtuner
You´re the man! Lol! Thanks
Old Mar 5, 2013 | 08:53 PM
ihiryu's Avatar
ihiryu
Whoa weird, I wonder why I never had this issue? Keep up the good work!
Old Mar 6, 2013 | 02:48 AM
99SC42's Avatar
99SC42
Because the person that built his patch harness wired the cam and crank backwards.
It happens sometimes.
