Urgent O2 sensor question
Old Dec 10, 2002 | 11:19 PM
kccapt's Avatar
kccapt
Question Urgent O2 sensor question
Guys/folks:
I had a new audio system installed which involved some re-wirng under the console,
I earlier had a diagnosis (Lexus and independent) of rear o2 sensor failire.
The Trac is not working (unsafe, with the power, dry; and undriveable wet or snowy)
They're telling me that the the O2's out cause the tandem Trac light to illuminate and prevents the Trac from engaging...(!!??)
I'm skeptical..any advice???
Old Dec 11, 2002 | 11:34 AM
mdfdsc300's Avatar
mdfdsc300
I sincerely doubt that the O2 sensor failure causes the traction control to not work. The "trac " light is illuminated for various problems/codes in the diagnostics including O2 sensor issues, but it should not disable traction control operation if that's what your asking.
Get a second opinion. Is it a Lexus tech that is telling you?
Old Dec 19, 2002 | 03:54 PM
Bladez42598's Avatar
Bladez42598
Default o2 sensor definitly causes TRAC NOT TO WORK
If you have a failed O2 sensor a sure sign of this is if your TRAC light comes on and doesn't go off. Hence causing your TRAC not to work, If you are also smelling a bad odor coming from your exhaust that's another sign of a bad o2 sensor....in my case thesewere the symptons along with an error code 25 and both front o2 sensors needed to be replaced.
Old Dec 19, 2002 | 11:37 PM
Chairmnofthbord's Avatar
Chairmnofthbord
Default check your codes
check to be sure, but it will turn your "track off" light on, and when the light is on it turns off the "trac" or so i remember when i had the same problem.
but ussually is your 02, they should be changed at about 100-120 miles, but nobody does until they go bad since there about $135 for the sub & $145 for the main.
if your in socal, and your car is OBD I i can check it for you.
mrblister
GX - 1st Gen (2003-2009)
Jul 23, 2025 03:24 PM
Tuantran
Jan 8, 2019 02:12 PM
iponnet
Mar 21, 2010 05:47 AM
tomv
RX - 1st Gen (1999-2003)
Dec 20, 2004 12:04 PM
