anyone have Pics on Dual Pump setup for in-tank?
Old Nov 25, 2012 | 05:06 AM
lexforlife's Avatar
lexforlife
Originally Posted by DoomLight
i really wanna keep it simple. everyone is telling me the walboro 400 is good. but i gotta upgrade the fuel lines to -8an and blah blah blah. i just want this car to make 500hp.
you dont need a -8n line .. stock line at 5/16 is not quite big enough to support flow on this big pump and you will burn it up .. a -6an line is perfect with a -6an return ..
this is very simple to do and this 1 pump will fit your needs with headroom to spare .. dont skimp on fuel and what i would also reccomend instead of using the typical aem uego wideband is get the aem failsafe gauge as it will protect your motor if this 1 pump drops pressure
Old Nov 25, 2012 | 06:46 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I made over 500 on a stock oem tt fuel pump. Had to upgrade to -6 feed line but kept stock return line.
Old Nov 25, 2012 | 10:24 AM
lexforlife's Avatar
lexforlife
on a denso 290 lph you can keep stock return , on a walbro 400lph design , without a -6an return or -8an return it will overrun your fpr ..
for around 500 ish a stock denso is okay , but for more headroom and less amperage draw go with the walbro and place a -6an bulkhead fitting on the fuel level sender cap and be done with it .. i use the stock feed and stock return fittings under the tank on pass side of car for a dual dump return into the slosh bucket .. the easier the fuel can return to tank the less friction occurs
Old Nov 25, 2012 | 04:16 PM
DoomLight's Avatar
DoomLight
I love all the info being put here. Keep it coming.
Old Nov 25, 2012 | 04:37 PM
gerrb's Avatar
gerrb
Super Moderator
Originally Posted by lexforlife
what type of fittings did you use out the fuel sender cap ...
those were -6an bulkhead fittigs on the sender cap .. fed by -6an/barb hose end coming from the pumps.... the cheapest place for E85 friendly fittings and SS braided teflon lines I found are at anfittingsdirect.com
I just use one right now .. but with room to expand with the other two bulkhead. Though right now, I am using one as a vent port for the tank since it is a requirement for the Weldon 2345a
this is the E85 friendly Racetronix hose that feed one port which costs less than $4 compared to a $25 gates submersible hose.
Old Nov 25, 2012 | 05:03 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Gerrb comes through yet again. Thanks man....
Old Nov 26, 2012 | 07:20 AM
DoomLight's Avatar
DoomLight
question. what if i ran dual pumps. in the in-line fashion.
so i can avoid tryin to figure out how to get the gas out the tank with only an external pump. couldn't i use a walboro pump to feed the aeromotive A1000?
i tentatively have this in trade for a chipped SARD 3rd GEN 3SGTE computer. but with all the results im seeing here. i am not sure what to embrace.
can a fuel pump like the A1000 be used for daily use? or would it be safer to run Dual Denso pumps?
yanno since they are OEM and reliable as hell.
Old Nov 26, 2012 | 09:11 AM
DoomLight's Avatar
DoomLight
i have done more research since i made this post. and this aeromotive pump is hit or miss. i think im going to go with Dual Denso pumps. its easier to hook up. plus u can't beat a fuel pump that can last over 150k without changing it.
Old Nov 26, 2012 | 10:12 AM
lexforlife's Avatar
lexforlife
for 500 to 600 hp a single walbro 400 is more then enough .. no need for dual anything unless you are going higher and even then just still do 400lph and a kenne bell boost a pump that activates under boost and raises voltage to pump to 16volts which at that point good for 700 on e 85 much less pump gas
Old Nov 26, 2012 | 02:48 PM
DoomLight's Avatar
DoomLight
i like that idea better. thanks lexforlife. i'll start collecting parts.
Old Nov 27, 2012 | 01:56 PM
Lagzilla's Avatar
Lagzilla
Great thread, EXACTLY the information I was looking for.
Old Nov 28, 2012 | 07:40 PM
Halon's Avatar
Halon
Couple pics of my poor-mans dual 255hp in-tank parallel setup. The Y-fitting I used I'm unhappy with, caused me to get creative and "loopy" with the fuel lines. Will be redoing with a different fitting and cleaning it up this winter.
Old Nov 28, 2012 | 10:30 PM
94_soarer's Avatar
94_soarer
I could of swore the walbro 400 was not E85 compatible... walbro 416 is tho right?
Old Nov 29, 2012 | 05:03 AM
DoomLight's Avatar
DoomLight
Driftmotion.com sells a walboro 400 pump thats E85 compatitble. its like 12 dollars more or something stupid like that.
Old Apr 27, 2017 | 10:13 AM
megamax's Avatar
megamax
bumppers, new pics, new ideas?
scweetfl02
Dec 28, 2011 04:50 AM
GTE_SC3
Jun 30, 2008 03:13 PM
JTJerryls400
Mar 9, 2005 02:22 PM
braheem
Mar 5, 2004 09:01 PM
