diy for sc300 brake boosters??
Old Nov 11, 2012 | 02:26 AM
grindin8o8's Avatar
grindin8o8
Default diy for sc300 brake boosters??
any one can help me out please? any step by step info? help would be appreciated. thanks
Old Nov 12, 2012 | 06:34 AM
Catracho30's Avatar
Catracho30
what do you need? removal help? its 4 bolts on the inside that hold it to the brake pedal and a pin . then remove the master cylinder on the outside which is 2 bolts and the assembly should pop out
Old Nov 12, 2012 | 06:03 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Kinda tight in there under the dash, but doable. Have small hands is better. Pretty straight forward.
Old Nov 12, 2012 | 10:32 PM
grindin8o8's Avatar
grindin8o8
thanks guys.
Old Nov 13, 2012 | 07:56 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I just went through my PDF and here are the directions as followed..
Remove the trac pump and disconnect wiring. Looks like 2 nuts and 1 bolt, and undo line.
Next unplug sensor going to master cylinder on the right hand side
Remove the 2 lines containing fluid
Remove the two rubber lines
Undo the 3 bolts around the master cylinder
Remove the rubber line going into the brake booster on top
Go inside car, slide seat all the way back
Lay on back
Undo the four bolts that actual hold the brake booster in place
Remove clip on clevis joint and lay aside
Pull brake booster out and replace
Replace gasket if needed, or make a new one
Put back in reverse order
If the brake master is leaking, then replace while out
When all stuff is put back in, pump brake pedal, and add fluid
Sorry for the delay, good luck, if you need pictures, post up!!! pretty straight forward.
Bleed brake system from PR, DR, FR, then FL, closet to master cylinder
Old Nov 14, 2012 | 02:06 PM
grindin8o8's Avatar
grindin8o8
Lay on back
thanks a lot 1jz. really appreciate it.
Old Nov 15, 2012 | 08:16 PM
IN2LXUAL's Avatar
IN2LXUAL
where did you purchase a replacement from?
Old Nov 17, 2012 | 10:29 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
your welcome man, if you need more, just ask. did you get it fixed?
brainsurge
Jun 24, 2018 08:59 PM
CreativeS
Suspension and Brakes
12
Nov 18, 2016 06:28 AM
mjr24
Oct 5, 2009 08:02 PM
dojoman
Dec 11, 2007 09:40 PM
fireballs gs400
Nov 13, 2003 03:25 PM
