Oil Pressure Gauge (Install)
Supra/IS300 union bolt --> 1/8-NPT male/male
T-fitting (center) --> to 1/8-NPT male/male
T-fitting (side 1) --> oil temperature sender
T-fitting (side 2) --> oil pressure sender
No leaks either, senders are as close to the engine as possible without actually being in the block
Did you guys ever think about using one of these ? This looks like the easiest thing and lets you keep the factory sending unit.
http://www.glowshiftdirect.com/oilfi...5thread-1.aspx
Shane
Shane
I used the union bolt and got the T fitting thing for the turbo Feed and put the sending unit at the end of it. That way you can still have the OEM sender unit. Plus its a good indicator for the turbo oil pressure, which will tell you that your turbo is getting good oil pressure to the turbo. so its a win win.
Look under the lower intake manifold and you will see the oil sending unit. This one is kinda big becuase I used the glowshift oil pressure gauge. The AEM sending unit is much much smaller you may know already.
knyg
Jun 2, 2017 12:39 PM
