resurface pads?
Old Oct 15, 2012 | 02:04 PM
1uzSC's Avatar
1uzSC
Default resurface pads?
I got some ebay ceramics and drilled slotted rotors. When i put them on my first sc4 the back right had a sticking guide pin and it made a noise. Now that i transferred them they still make the noise. Are the pads/rotors screwed? Also how important are the triangle clips that connect to the two pads?
Old Oct 16, 2012 | 07:19 AM
TweakTech's Avatar
TweakTech
Are they squealing, or just making a scuffing noise? Also, if you didn't fix the issue of the sticking set pin the first time, the pads/rotors could have abnormal wear, and in this case, yes, they're screwed. Drilled/slotted rotors are not able to be turned.
Buy some decent OEM replacement pads and rotors from your local auto parts store and install them. If you notice that any of the components on the caliper are sticking, or not functioning properly, FIX IT before you drive it and potentially wear out more hardware.
Old Oct 16, 2012 | 07:40 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
the clips are very important they keep everything in the right place so you can break. you can get replacement spring clips from the dealer they arent that bad.
Old Oct 16, 2012 | 11:55 AM
1uzSC's Avatar
1uzSC
Ty for the info. Can i use the ls400 clips from a junkyard?
TOLex168
18
Feb 23, 2018 08:15 AM
RealMCR12
RC - 1st Gen (2015-present)
Feb 18, 2018 10:32 AM
Fife
Nov 9, 2014 05:33 AM
4uhaterz
Jun 15, 2009 10:46 AM
Rock-a-Lex
Suspension and Brakes
May 17, 2007 10:36 AM
