O2 Sensor problem FINALLY SOLVED!!!!!!!!!
Old Jun 22, 2010 | 07:11 AM
  #46
skirts's Avatar
skirts
I have been having o2 problems as well. I can put new sensors on and the light still comes right back on. If i can get my hands on an obd-1 scanner what should I look for and do I need to look into getting a new tps??
Old Jun 30, 2010 | 03:33 PM
  #47
BostonSC4's Avatar
BostonSC4
Originally Posted by Baraka
The pic of the DLC1 connector is below. If you can actually get it open, follow the instructions here:
The EFI fuse can be found by opening up the fusebox (big, black box on the right hand side of the car, under the hood w/ two screws) and looking at the labeling on the back of the cover. If anyone wants a labeled pic, I would be happy to post it. Just ask.
Baraka, take a flat head screw driver to the side where the clip is towards the rear of the engine. Start trying to separate the diagnosis box first, then put the flat head in there and pry it open. Works like a charm and takes about 3 seconds.
Old Aug 17, 2010 | 06:39 AM
  #48
BobbyB's Avatar
BobbyB
Default O2 sensor
Originally Posted by Taka
I just replaced my o2 sensor 2,3 weeks ago. I took some pictures so I can write up the page shows how to replace o2 sensor etc..
I got code 25 as well, but after the reinstallation, it feels much stable condition.
Can you give me the link for the 'how to' change the O2 sensor you wrote up..thanks.
Old Nov 14, 2011 | 04:01 PM
  #49
lithium14's Avatar
lithium14
Hate to revive an ancient thread, but my 92 SC400 threw codes 21 and 28. I replaced both main o2 sensors yesterday and reset the ECU by pulling the EFI for 10+ min, but after a few minutes of driving, it threw codes 21 and 28 again. I see many people on here are having the same issue, but there are no solutions. Anyone that posted here before with said o2 codes, what did it take to fix it? How is the TPS related to codes 21 and 28? Thanks
  #50
lithium14's Avatar
lithium14
Also to add, I have no running issues, the car pulls hard at all speeds, but I do have a high idle (1100 rpm)
Old Mar 6, 2012 | 09:39 AM
  #51
WadeLovell's Avatar
WadeLovell
Any update on your status or solution?
Old Mar 7, 2012 | 03:30 PM
  #52
lithium14's Avatar
lithium14
nope sorry. I'm going to get my Supra up and running before I divert any attention to the SC.
Old Mar 23, 2012 | 01:14 PM
  #53
coreytat's Avatar
coreytat
has anyone tried replacing or testing your knock sensors I ran test on mine today with a o scope and found irregularity in the pattern have ruff idle sometimes fuel smell from running rich even though it says its running lean in open loop (at Start up gettin to operating temp)
Old May 11, 2012 | 04:32 PM
  #54
dvierra329's Avatar
dvierra329
your right about the lean code but the universal o2 sensors wont work without modifacation i took the oem o2 sensor cut everything off the play then had to drill nd tap the threds for the universal sensor it was 40 bucks for the 2 upstream sensors then another 40 for the machining buying the replacements saves me 100 dollars but what i dont get is my car is running lean but it gross polluted on hydrocarbons but thats unburned fuel i believe
Old May 22, 2012 | 09:11 PM
  #55
MidnightR's Avatar
MidnightR
I just did the 2 mains with Denso O2's along with 2 high flow cats and I still have the lights on which code 21. I see someone did the actual code reader and got the TPS but when you did it yourself did you get the O2 sensor?
Old Oct 30, 2017 | 11:12 PM
  #56
Craigls400's Avatar
Craigls400
I changed and inspected all my spark plugs today, the white smoke was less and so was the gas fumes , i am gonna run a straight pipe after the resonator and replacing my front o2 sensors first cause my motor is lean and pushing more fuel , injectors will be tested and flush of the radiator and heater core , found a clean lexus at the salvage yard to pull parts off , ecu for $40 , grill for $30 ish , getting coil overs , used spacers on front to clear aftermarket rims from touching calipers, replace those wheel studs for longer ones, this eebsite/ discussion biard is very helpful
Old Nov 26, 2019 | 02:08 PM
  #57
mxfan125's Avatar
mxfan125
Do you have that by chance? I am trying to do the Bank 2 sensor 1 and do not want to take off the exhaust manifold
srt1
Aug 28, 2024 01:35 AM
MsbTTSupra
Feb 21, 2020 07:27 PM
Gunnut
Jan 27, 2008 10:35 AM
Fern
RX - 1st Gen (1999-2003)
May 29, 2007 10:57 AM
t0ekn3e
Feb 13, 2007 12:42 PM
