Power steering completely dead
Old Sep 21, 2012 | 08:51 PM
DJTURCIOS's Avatar
DJTURCIOS
Default Power steering completely dead
hello, i just bought a 1992 Lexus SC400 with around 164xxx miles. power steering is completely out, put fluid in, NOTHING. the serpentine belt is working fine. No grinding noise, NOTHING. i have never encountered something like this. This is my first Lexus & i don't know where to start looking for the problem.. any help is much appreciated, thank you.
Old Sep 21, 2012 | 08:58 PM
OG Dada's Avatar
OG Dada
Does it have a leak? Can you check the ventilation hoses if they're attached? One goes to the front part of the manifold, another one goes to the intake, and both go back to the high pressure hose on the power steering pump side.
Old Sep 22, 2012 | 05:29 AM
DJTURCIOS's Avatar
DJTURCIOS
Not that i can physically see. & if it didn't have any fluid, wouldn't it be making a whining sound? ill try to look more into it as possible. Haven't had a chance since i work almost everyday. thank you for the reply!
Old Sep 22, 2012 | 09:09 AM
OG Dada's Avatar
OG Dada
If it's whining it's either out of fluid or there's air in the system. To check if there's a leak, move the boot of the inner tie rods so you can see the inside, it is supposed to be all dry in there, if there's fluid, then it is leaking and you need to change the rack and pinion. Another common source of leak is the high pressure hose and the hose that goes from the reservoir to the PS pump.
Old Sep 23, 2012 | 07:33 PM
DJTURCIOS's Avatar
DJTURCIOS
No leaks whatsoever. i added powersteering fluid since it got really low & started whining. powersteering is alive in a way. steering when from dead to tough but not dead. Ive filled the reservoir 3 times today. Powersteering fluid keeps disappearing. No leaks like i said
Last edited by DJTURCIOS; Sep 23, 2012 at 07:34 PM. Reason: added more information of the issue
Old Sep 23, 2012 | 08:20 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
The fluid is going somewhere. It either has to be leaking into the alternator and you cant see it or the rack somewhere. Really only two places it can be. Keep an eye on it, carefully. It might take out your alternator if in fact it is leaking from it.
If indeed you find the leak and it is the pump, follow this thread. Very detailed write up. Works same way...
http://www.lexls.com/tutorials/steering/
Old Sep 24, 2012 | 12:26 PM
DJTURCIOS's Avatar
DJTURCIOS
again my resevoir is very low. it has to be a massive leak to be leaking like that... & my engine oil level has risen. WTF?
Old Sep 24, 2012 | 01:40 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
It's your vacuum valve.The vacuum valve is a switch on or near the power steering pump. 2 vacuum lines attach to this switch. When the switch itself develops a leak, the power steering fluid gets sucked into the engine. Eventually the leak grows and you will start seeing white smoke, and will recognize the "rich start up" It won't smell to good either. That part should not be to costly either. So were is your power steering fluid going? Into the engine and then into air. If I'm not mistaken the vacuum valve is around $100, or if you don't want to spend that much money get a used one. I'm sure aliga has one or two or fourteen he would be able to locate for you. Sewell Lexus might as well. Both of those CL members are vendors so just search them up in "vendors" Good luck and make sure to post the problem when done!
Old Sep 24, 2012 | 04:46 PM
DJTURCIOS's Avatar
DJTURCIOS
HOLY SHII!!!!!!!!!!!! THAT MUST BE IT!!!!!!! I AM DEFINITELY HAVING THE RICH STARTUP!!! white smoke everywhere!!! Powersteering fluid is gone again... Thank you!!!! I'll replace the valve & report asap.
Thanks again!
Old Sep 25, 2012 | 10:48 AM
chestman88's Avatar
chestman88
I have the same problem, exhaust blowing white smoke on start up, and having to refill power steering fluid every 2 days. Where is the vacuum valve located? I read somewhere you can just plug it up. Only problem is that I don't know where it is. Can someone show me where the vacuum valve is located on the power steering?
thanks you
Old Sep 25, 2012 | 12:53 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
The vacuum valve is known I think as the ACV, or air control valve. Not idle air control valve. The valve will be on th ps pump and probably will be black. You will know it when you see it because of the two nipples sticking out of it for the two vacuum hoses. It is attached directly on the ps pump. Good luck!
Old Sep 25, 2012 | 01:16 PM
chestman88's Avatar
chestman88
I remember reading some where in the forum the only the LS400 have the 2 nipple thing you were refering to and sc don't have it. that is why I am sooo confuse/lose in locating the vacuum valve
Old Sep 25, 2012 | 04:02 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
I think the SC does have it. The one CL user that mentioned that had only 1 post, so I don't know if he is the best resource with 4 or 5 other people saying it does.....just my 1 and a half cents. Search the internet for a diagram.
Old Sep 25, 2012 | 07:59 PM
DJTURCIOS's Avatar
DJTURCIOS
Nope. SC400 have it as well. Its located on the Banjo fitting that goes on the powersteering pump. I went to a local salvage yard found one from a 4runner, installed, by by smoke. steering is still tough though...
Old Sep 26, 2012 | 09:30 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
What do you mean by the statement: "Power steering is still a little rough though"? How is it rough? Did you fill the PS container up afterwards?
