Coolant bleeder valve 92 sc 400
Old Sep 20, 2012 | 11:46 AM
speedmike's Avatar
speedmike
Default Coolant bleeder valve 92 sc 400
Changed some PS pump hoses and changed the coolant tank sensor and now the bird cage is on. the system has coolant I need to bleed the system and I have never done it. I've read that there is a bleeder valve but I have also read to park the car up hil yada yada yada.... does anyone have a pic of the valve???
Old Sep 20, 2012 | 01:02 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Its pretty easy to locate. It on the top in the middle/forward of the motor. Size 17mm screw, if I aint mistaking. Jack the front end up as high as you can, turn heat on high on the floor only, and let it bubble out. When bubbles are done and the upper hose is really hot, all is good, and the light should go off. Try also undoing the battery for a few and see if it will reset.
IS_Sunny
Dec 16, 2013 12:09 PM
mark_t
Dec 13, 2011 01:53 PM
lowKut
Aug 28, 2009 11:51 AM
kphu
GX - 1st Gen (2003-2009)
Jun 30, 2008 04:48 AM
Pianoman72
Maintenance
Oct 11, 2003 05:13 PM
