injector and what?
Old Aug 27, 2012 | 07:32 PM
biturbo632's Avatar
biturbo632
Default injector and what?
I know there's a lot of 2jz swap' sc300/400 here! So I would know..
I drive an 1991 Toyota Soarer recently swapped with an Aristo 2JZ, so it's all japanese for now, and I want to upgrade to refurbishing my turbos with www.driftmotion.com.
see here: http://store.driftmotion.com/static/...rboupgrade.php
I have already greddy FMIC, 3inch exhaust, greddy type S BOV, AEM FIC installed with the aristo 2JZ ECU.
For know, my buddy told me I need SARD 800cc injector, and that they are bolt-on.
So.. is that it? I would certainly need something else?
fuel rail? / fuel line? / fuel regulator / usdm resistor box / fuel pump? / ...?
I know just to run USDM 550cc injector I need the resistor box.. for the SARD 800cc do I?
Please help me! I'm running into, for now, something I don't know and I don't want to mess it up!!
Thanks!
Old Aug 27, 2012 | 08:08 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
you can keep the stock rail if the injectors are side feed, which is usually more expensive for larger injectors.
if you go with top feed, you will need a top fed fuel rail conversion.
your ecu is looking for high impedance injectors.
If the injectors you buy are high impedance, yo do not need a resistor box.
If you buy low impedance injectors, then you will need to wire in a resistor box.
Old Aug 29, 2012 | 09:12 PM
biturbo632's Avatar
biturbo632
Man! You just answered me a lot of questions here!
Thanks!!
Proamas
Performance
Apr 10, 2017 08:38 AM
Toughtruck
Performance
Apr 4, 2016 09:45 AM
s1984
Mar 28, 2013 07:25 PM
tampa mike
Apr 2, 2009 12:58 PM
indypwr
GS - 1st Gen (1993-1997)
Feb 13, 2004 04:45 PM
