Wiring Issue Please Help!
Hey guys I am in need of your expertise. I was having electrical issues with my 1993SC400 (car alarm going off randomly, dash lights going on and off) and discovered I had water in the drivers side of my trunk where there is conveniently a bunch of wires. I drained the water out and routed the drain hose to the proper location so it wouldnt happen again.
The issues were fixed except now my head and taillights will not work. They come on for a millisecond then go right back off. I inspected the white wire connector only to find that (apparently) the submersion in water caused the wires to heat up, melting a hole in the center of the connector and loosening two wires. I am no expert but I am sure this is causing my problems. The loosened wire was White with a blue stripe and black with a red stripe. I cant find a new connector anywhere at the local parts stores or online. Everything else works perfectly in the car.
I am hoping there is a way I can bypass the connector possibly?
Please Help! This is my daily and I can only drive during the daylight currently. Thanks!
