SC400 Neurosurgery - wiring harness repairs
Old Aug 15, 2012 | 07:25 PM
zeus87gn's Avatar
zeus87gn
Question SC400 Neurosurgery - wiring harness repairs
I had started a previous thread because my SC wouldn't start - determined I had a short in the wiring harness - pulled out the main harness from the ECU/engine and found lots of heat singed wiring - I have been working on it now for a few days and ran into a problem - pic #1
Problem: the FI plugs are breaking apart as I remove the pins to solder on new wires - pic #2 - not even the Lexus dealer knows if I can just get new plugs w/inserts - of course, none of the typical parts stores have any listings - anyone know where I might can get some new ones? - I'm headed to a couple of salvage yards tomorrow to see what I can find - there are a few more plugs that need replacing too, so I may be able to find used replacements
Last question - I have found this jumper (pic3) in the common circuit of the right side set of injectors - there isn't one like this on the left side - I thought it might be a connection for a noid light, but i can measure about 7ohms of resistance across the jumper itself (??) - is this device needed for normal operation? - does anyone know?
Any help is appreciated - TIA
PS - what?! no beer smiley??!!
Attached Thumbnails SC400 Neurosurgery - wiring harness repairs-auto-surgery.jpg   SC400 Neurosurgery - wiring harness repairs-fi-plug.jpg   SC400 Neurosurgery - wiring harness repairs-jumper.jpg
Old Aug 16, 2012 | 07:18 PM
zeus87gn's Avatar
zeus87gn
Well, I found some good FI plugs on a couple of 4 banger Toyotas and have them wired into the harness
Studying the schematic to find out about the jumper - havent found anything yet, but still searching
Old Aug 17, 2012 | 07:21 PM
soarer479's Avatar
soarer479
If you need new injector clips they can be purchased on eBay just look for Denso style injector clips
Old Aug 17, 2012 | 09:12 PM
zeus87gn's Avatar
zeus87gn
Had to replace the entire connector(s) for the FIs - ive got all the needed wiring repairs complete now -- i went through an entire 35' roll of new 16awg and 5' of 10awg green wire replacing the grounds alone - been splicing/soldering for 2 weeks now -- im starting to feel better about the motor actually starting now -- the wires were in such bad shape from the engine heat
Old Aug 17, 2012 | 09:13 PM
zeus87gn's Avatar
zeus87gn
Well it seems like 2 weeks...
Old Aug 18, 2012 | 06:45 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
If you decide to give up, I believe OLT has a full uncut harness. I maybe mistaken, but I have seen a picture of one on here in his attic in a different thread of his.
Old Aug 18, 2012 | 12:47 PM
zeus87gn's Avatar
zeus87gn
Nope - wont be giving up at this point - too much time invested - im actually fitting the harness back onto the engine at this point - all the FI plugs are replacements now but all have working lock clips
I figured out the jumper has no relevant use in the harness so i left it out
Old Aug 22, 2012 | 06:10 AM
zeus87gn's Avatar
zeus87gn
Ok, so I got the starter to turn the engine - YAHOO!!
The work I put in on the harness has paid off
Now I have to get it to fire
My sons friend discovered a cut wire - unfortunately it appears to be the lead to the d/s cam sensor
Would that stop both coils from firing?
Old Aug 22, 2012 | 08:34 AM
cartmill's Avatar
cartmill
looks like fun!
Old Aug 22, 2012 | 05:13 PM
zeus87gn's Avatar
zeus87gn
My time paid off - IT LIVES!!!
I had bad wires on the cam position sensors
I also had the sensor harness connector (up by the FI plugs) plugged in backwards!
The outside of that 6pin connector was broke off
Another case of heat singed plastic
Old Aug 23, 2012 | 02:39 PM
SC400DAVE's Avatar
SC400DAVE
I'm glad you found the problem. Harness repair is not for the faint of heart. I found this place that can repair harnesses or supply us with pigtails and new connectors. I thought I was going to need my HVAC harness repaired. I hope this helps someone out there with harness problems:
http://www.aeromotive.us/index.html
For repairs or diagnosis:
http://wireharnessrepair.com/Home_Page.html
Old Jul 8, 2024 | 08:16 AM
premiertlc's Avatar
premiertlc
6th Gear
Hello,
I see that you have removed your engine wiring harness I also need to do the same on my sc400 if possible could you give a source and some tips on removing it from the vehicle without damaging or cutting any wires
Thanks any info will help!
G000BER
May 31, 2014 01:51 AM
BOPOH
Sep 28, 2012 01:42 PM
shhhmoke
Jun 9, 2012 10:14 AM
tampa mike
May 22, 2012 09:52 AM
sniper
SC400 / 300 Classifieds
Sep 22, 2008 10:08 PM
