SC3 engine body harness help.
Old Aug 1, 2012 | 11:08 PM
96blksc300's Avatar
96blksc300
Default SC3 engine body harness help.
Not sure if this is the right section.. but since there is not a wiring section i am posting it here.
I'm doing a GTE swap on my SC right now and while the engine is out i'm going to paint my bay. So i am in the process of pulling everything out of the bay. The problem i have run into is where the harness goes in on the driver side (pass side is already out). I have all of the plugs out except for one that i can seen to get to. It seems to go behind the fuse panel. I cant seem to get the fuse panel out either. Anyone got any suggestions on how to get the drivers side fuse panel out? its the section of the fuse block that is closest to the firewall if the fuse block separates into more than one piece as the passenger side does.
Any help would be appreciated as i need to get this out and start prepping for paint as soon as possible lol.
Old Aug 1, 2012 | 11:30 PM
96blksc300's Avatar
96blksc300
Ok so after some further digging i found a thread by Dustin2JZ that is in reference to the "tire well harness relocation". there is a picture that shows the wire i am talking about and i believe that it is for the wiper motor. when i unplugging th harness and trying to pull it through i was going to pull the rubber bulkhead and all.. but in this pic he has.. if i was to just cut the rubber boot on the bulkhead and pull the wires i already have unplugged then the other "trouble wire" will stay where it is. figured i would post this update in case someone else was searching for the same thing.
Dustin2JZ.... hope you dont mind me using your pic. I'll take it down if you want.
its the wire that is going into the firewall here that is routed to the top.
soardrft
SC400 / 300 Classifieds
Feb 20, 2017 08:37 AM
Jooee
GS - 1st Gen (1993-1997)
Apr 21, 2013 06:46 PM
cheez
Oct 3, 2011 09:01 AM
JDMmuscle
Aug 18, 2008 12:02 AM
