HELP r154 speedo
Old Jul 29, 2012 | 06:23 PM
jwin's Avatar
jwin
Default HELP r154 speedo
Do you install the marlin crawler speedo sensor in that? Do I need the mechanical speedo. The marlin crawler takes the place of the speedo cable am i correct and will it will work on my 97 sc300.
Old Jul 29, 2012 | 06:49 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
That is correct. Remove that, screw in the MC and then wire in the two wires to get the reverse light to work correctly. Remeber also to pull the P,N,D,2,1, if you converted from an auto to manual.
Old Jul 29, 2012 | 07:30 PM
ihiryu's Avatar
ihiryu
Yup that's what I did too
Old Jul 29, 2012 | 08:41 PM
charley240's Avatar
charley240
Yes, screw the mc adapter to the speed sensor. Its not necessary to remove the speed sensor to install the mc adapter. Also, you may want to replace the 2 seals on that speed sensor, 1 goes on the outside, the other goes on the inside, it will prevent your mc adapter from being flooded with gear oil.
Charley
Also, is that from an 89+ mkiii supra?
Old Jul 30, 2012 | 05:39 AM
99SC42's Avatar
99SC42
Like they said on the speedo and please don't hack that mount and your cross member like some have, just buy a W58 mount and it will work great! and you deal deal with vibration and stuff.
gl
Old Jul 30, 2012 | 12:00 PM
jwin's Avatar
jwin
Could you go into some detail with pulling the p,n,d,2,1. What do I pull. What about the abs sensor that they sell on driftmotion. Does that go on the other side in roughly the same location. The reverse sensor is on the same side as the speedo with two wires coming out of the sensor?
Old Jul 30, 2012 | 12:34 PM
jwin's Avatar
jwin
Which w58 crossmember should I use?
Old Jul 30, 2012 | 10:04 PM
zerodragon's Avatar
zerodragon
whatt ic mc part #
Old Jul 30, 2012 | 10:06 PM
jwin's Avatar
jwin
Originally Posted by zerodragon
whatt ic mc part #
http://store.driftmotion.com/static/...crawlervss.php
Old Jul 30, 2012 | 11:30 PM
zerodragon's Avatar
zerodragon
thanks was looking for this
Old Aug 3, 2012 | 07:23 AM
marshall2j's Avatar
marshall2j
Subscribed. Will be swapping to R154 and need this helpful info
Ozzzzy
Jun 23, 2018 04:12 PM
2jzlex
Apr 6, 2018 01:19 AM
trufanatic
Oct 13, 2010 10:09 AM
4000GT
May 18, 2008 03:28 PM
D1GP
Mar 7, 2007 03:27 PM
