Small question
Old Jul 17, 2012 | 08:04 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Default Small question
My question is about that vacuum line. The guy before me that owned the car messed and melighned with it, and somehow broke a vacuum line. (the plastic connector)
Do you guys think I should even worry about fixing it? I ran the engine with it like that and blocking it and all that, but nothing changed. What do you think?
I'll have pic soon.
Old Jul 17, 2012 | 08:28 AM
/Aerostar\'s Avatar
/Aerostar\
Yea fix it, there should be a diagram on the underside of the hood for the vacuum line routing. If not, then there definitely is in the service manual. You'll probably need 4mm vacuum line, available from Autozone for ~$1 a foot
Old Jul 17, 2012 | 10:49 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Thnx! (The service manual is very hard to find and very costly!)
pic will be up soon
Old Jul 17, 2012 | 10:53 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
OK, finally. Here's the pic(s)
Old Jul 18, 2012 | 08:59 AM
/Aerostar\'s Avatar
/Aerostar\
That looks like the EGR saucer or modulator. On eBay they're $30 which is kinda steep, Aliga can probably get you one cheaper
http://www.ebay.com/itm/Lexus-Toyota...#ht_720wt_1164
You may not notice a difference at idle, but I would think it would have an effect at higher rpms
Old Jul 18, 2012 | 09:15 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
OK, it was idling at about 900 RPM's...
I'll think about it. I had looked at the diagram under the hood and it looked like it went into something like the EGR...
much obliged.
Old Jul 23, 2012 | 02:41 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
OK, I got the vacuum lines for a couple bucks. the broken plastic connector in the EGR modulator was in the hose so I cut the hose and got it out, than I tried to glue it but super glue didn't stick for some reason.
I don't think it's absolutely necessary to replace the EGR modulator, sooooooooo.......????
mikemu30
RX - 4th Gen (2016-2022)
Aug 22, 2017 08:02 AM
zneubauer
Feb 12, 2017 12:01 PM
raytseng
Jul 31, 2014 04:02 PM
Chronolick
Mar 1, 2013 02:12 PM
sc3dreamz
Dec 11, 2006 10:11 PM
