Bad tranny mounts?
Old Jul 15, 2012 | 08:17 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
As soon as the TPS got here, we replaced it. and the idle STUNK! it was worse than when we started. We played around with it, and nothing changed. I was thinking we should not of touched the TPS.
Well, then we moved the throttle cover, (plastic piece over throttle body, and the cruise control and throttle was COMPLETELY loose. tightened and then the idle all the sudden purred. Took it out for a test drive, did everthing to try and make it to surge and buck, but wasn't able to. There was still a ever so slight surge, but that will be gone when engine mounts get replaced.
Problem SOLVED=TPS and throttle bolt
Wow, what a month....
Old Jul 15, 2012 | 02:48 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Originally Posted by account2x
replace engine mounts
How do I?
I've looked everywere. can't find a DIY
cheers
porn-adkt
Mar 8, 2013 10:17 AM
tomei
May 3, 2010 03:24 PM
suloh
Maintenance
Oct 30, 2005 05:43 PM
