my "HELP ME C.L."thread
Old Jul 12, 2012 | 09:08 PM
  #31
megamax's Avatar
megamax
Originally Posted by blk&blu*j
Wrong this is a pressed fit sprocket and they can and do come off just check to remove the possibility!!!!
GODDAMMIT!!! now i gotta remove the bumper/radiator wtf!!! **** my life!!
Old Jul 13, 2012 | 06:50 AM
  #32
cartmill's Avatar
cartmill
the problem is not the crank angle sensor.
you said your car runs when you spray starter fluid into the intake, so the engine is sparking.
the ECU uses the same RPM signal (crank and cam sensors) to fire the coils and the injectors.
the problem is:
the injectors, all 6 of them (FIX = REPLACE INJECTORS) --unlikely
the ECU controlling the injectors (FIX = REPLACE ECU) --somewhat likely
the wiring to the injectors (FIX = CHECK THAT EVERY INJECTOR HAS A SIGNAL PULSE AND SWITCHED 12v AND REPLACE WIRES IF NECESSARY) --most likely
does any of this make sense?
you're in over your head.
Old Jul 13, 2012 | 08:07 AM
  #33
blk&blu*j's Avatar
blk&blu*j
the problem is:
Totally agree
X2^^^^^^^^^^^^^^^
Old Jul 13, 2012 | 11:02 AM
  #34
PoGikoSc4's Avatar
PoGikoSc4
^^^ i also agree with Cartmill...now this make sense to me.. i dont wanna open up another thread about this so am just gonna bum off Jim if thats cool.
Old Jul 13, 2012 | 12:39 PM
  #35
megamax's Avatar
megamax
^^piko that is totally fine. i will try to get this youtube video up today!!
Old Jul 14, 2012 | 08:52 AM
  #36
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
it takes about 30-45 minutes to open up your ecu for the first time depending on how delicately you go at it.
then you can take a peek inside and rule out your ecu, which 1jz ecus are the ones most known for going bad
Old Jul 14, 2012 | 11:43 PM
  #37
megamax's Avatar
megamax
here's video #1 people. and got then installed a 1jz map sensor.
Old Jul 15, 2012 | 12:18 PM
  #38
megamax's Avatar
megamax
video #2
  #39
megamax's Avatar
megamax
the problem is:
where is the ecu that controlls the injectors??
Old Jul 15, 2012 | 01:20 PM
  #40
soarer13oy's Avatar
soarer13oy
The ecu that controls the injectors is the ecu itself. It grounds the injectors which then fires the injectors. Looks like you might have a wiring issue, but check the injector fuse in the engine bay fuse box to see if its blown.
Old Jul 15, 2012 | 01:55 PM
  #41
megamax's Avatar
megamax
^^well just checked that fuse. it was fine and replaced it anyway. tried to fire it up and still no dice.
anyone wan't to to a harness job for me??
Old Jul 15, 2012 | 02:06 PM
  #42
soarer13oy's Avatar
soarer13oy
Who did your wiring for you?
Old Jul 15, 2012 | 02:51 PM
  #43
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Ok. here is my turn. I would not trust any if the wiring since you didnt do it. Unplug the injectors, all six. check the polarity and see which side is getting ground and positive. write that down. now run NEW wires to the injectors, all six. wire them in batch mode, which is 1-4, 2-5, and 3-6. In other words when you run the wires, wire those together but on the trigger ground side. you can leave the positive side on the injectors from the stock wiring harness. if you still dont trust that, then run a seperate relay triggered on by the kick panel, then trigger the injectors that way, the way i did. does this make sense. if you run new wirez and check for ohm resistance and power, you have eliminated one less problem. if you cant figure it out, i will call you when i am back from vacation.
Old Jul 15, 2012 | 03:01 PM
  #44
megamax's Avatar
megamax
Emil-account2x member on here.
Old Jul 15, 2012 | 03:07 PM
  #45
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Hang in there, i know it is frustrating ... believe me i know. try to check to see if there is any resistance on all the injectors. Then try my method. That is what me and Cartmill had to do.
