Oddest check engine light issue ever.......
Jun 11, 2012 | 06:14 PM
Start car, bright light... wait and it FADES out?!?! Then never comes back bright when driving just comes back very dim. Variable brightness as you are driving. REALLY weird.
Jun 11, 2012 | 07:14 PM
i must ask, is the cel lit with a led?
Jun 11, 2012 | 07:45 PM
no led's anywhere except where they should be. It's an old school "16" white and red waterfalls, but no led's anywhere else.
I think a sensor is kind if going bad and kind of triggering it, but kind of not going bad and making it vary it's brightness as I drive randomly.
Jun 11, 2012 | 08:14 PM
Your probably right, i searched google to ee if other cars get it and i seems to be a issue with ford focuses dash clusters.
Jun 12, 2012 | 06:28 AM
Does the car always run fine? I think another guy on here had some CEL strangeness and it ended up being failed ECU caps.
Jun 12, 2012 | 03:50 PM
I recommend you check what the code is first.
Jun 12, 2012 | 07:16 PM
Can't because it comes and goes. That's what is weird about it. It acts like it isn't sure it wants to even throw the code.
Jun 12, 2012 | 07:47 PM
Maybe try to swap in another cluster and see if it still does it?
Jun 12, 2012 | 09:39 PM
Cluster indicator lights do not go through the main board, that is for backlight, needles, and the time/odo. Indicator and warning lights simply "pass through" the cluster, they are controlled by the sensor they are connected to.
Jun 12, 2012 | 11:01 PM
Quote:
Originally Posted by
O. L. T.
Ah, had no idea lol, thanks for the info
Usbustosmc
Jan 2, 2019 07:57 PM
73446
Jun 29, 2012 11:03 AM
UR2slow88
Nov 19, 2010 08:09 PM
swat1727
Sep 21, 2008 03:54 PM
VehicularL
Feb 4, 2005 10:03 AM
