help
Old Jun 7, 2012 | 02:34 PM
bighead222's Avatar
bighead222
Default help
why would there be coolant on top of the spark plugs its a 95 ge 5 speed with 130,000 miles on it
Old Jun 7, 2012 | 02:40 PM
mak89's Avatar
mak89
Blown gasket or cracked head, which leaks coolant into the head. Sure its coolant? pics... Also hows your coolant level looking?
Just reread your post. Is it on the tip of the spark plug that within the head or where the coil connects?
Old Jun 7, 2012 | 02:49 PM
Batiatus's Avatar
Batiatus
There is a hose that connects under the intake that might be leaking. I would check that first. Its connected to the throttle body.
Old Jun 7, 2012 | 03:01 PM
INTIMAZY's Avatar
INTIMAZY
Coolant ON TOP of plugs? That's less likely a headgasket but cracked head can't be excluded from the information provided alone. Has the motor overheated or is the coolant muddy brown?
Old Jun 7, 2012 | 03:30 PM
bighead222's Avatar
bighead222
Not sure if been over heated before,the coolent temp remains normal,and yes its on top of the coils,and theres no white smoke coming out the exhust and the car runs fine till all the coolent gets over it,and in coolent level is normal
Old Jun 7, 2012 | 06:16 PM
mak89's Avatar
mak89
Might be one of the coolant lines. Or its just oil from your valve covers.
Old Jun 7, 2012 | 06:54 PM
bighead222's Avatar
bighead222
Thks Mark im ganna change all the lines and take it from there,hope fully that will fix it.
aespinalIS
Build Threads
Mar 13, 2015 12:37 PM
CLRH2O
Feb 18, 2014 05:25 AM
teedup55
GS - 1st Gen (1993-1997)
Jun 9, 2010 07:25 PM
jimmac79
Jun 22, 2007 11:58 PM
tccsmith
Jun 28, 2006 09:45 PM
