Dashboard Dummie light on..
I have a little issue, The light on the cluster for the rear lights is on and I cannot seem to find a burnt bulb that would cause this to stay on. Literally spent 3 hours yesterday testing and pulling every singel light I could find.
Does anyone have any other suggestions? places to look...etc etc?? Any help would be greatly appreciated!
Thanks
Thanks
make sure you check the turn signals, reverse lights, make sure both filaments are working on all the brake lights I.E. all the dim lights when you turn the headlights on as well as the brighter ones when you actually step on the brakes. and dont forget to check the bulbs in the rear glass that are in the subwoofer cover (if your car has them)
if you have a rear spoiler check the led strip thats inlayed into the spoiler, im not 100% sure this one trips the dummy light though, in fact im pretty sure it doesnt
if you still cant find anything you might want to take out the taillight malfuction ecu and see if you can find any cold solder joints
I will update later!
That was already my plan, was considering that to be a possible issue as well. Luckily we have all the neccesary stuff needed here at the shop!! we shall see the end result!
So yesterday I litterally pulled, replaced all bulbs and put contact oil on every socket.... Light is still on.. FML... Starting to think the bulb may have to come out of the cluster!! Something about that bright light on, just cant stand to look at it!!!
This is really bugging me cause I really like to have my car 100% correct..
Anyone else have any other ideas?? Or know if I were to put a scan tool on it, Would it identify the exact location??
by anychance do any of you have led lic plate bulbs if so theres your reason. i have the same issue thats all it is.. or if you have replaced your head lights with hid's or the drl's. i havent really looked into the systems but im almost positive that the lic plate bulbs and the drl's run off the channel not the same circut. so when i acually get a chance i gotta do a lil more research but im almost positive that its 1 of those..
ya cuz i never had that light on and i installed hid's and led's and like a hour later mine turned on. so i checked all bulbs and sockets and everything is clean and good on mine so i said F it.. i do have to say steve from XenonDepot is a huge help with this i got my stuff from him and i couldnt b happier by far the best i have ever used/seen too.. thats his name on here. mayb he could help out a lil better but thats the man for lights..
yes, it is in the trunk on the drivers side. you have to pull off the side cover and it's behind the "pillar" of sheet metal below the trunk lid hinge. it should be a small yellow box, unless they changed the color of the box for your particular year
it's a very common problem in the supra, so it's a good place to check for malfunctions
here's the write up on the supra
http://mkiv.com/techarticles/failed_...fix/index.html
