Smog test failed at low speed
Old Apr 25, 2012 | 05:57 PM
dtLS400's Avatar
dtLS400
Default Smog test failed at low speed
My 92 sc300 5 Spd just failed the hydrocarbon test. I was measured at 119 ppm which is 15 ppm over the maximum 106 ppm for HC. Wtf!!! The high speed check passed with no problem ,,
Anyone have this happen to them?
I'm
Thinking I have an exhaust leak in between header and block...
Old Apr 25, 2012 | 07:33 PM
japsc85's Avatar
japsc85
samething happened to me about a week ago but my number was 245 and needed to be under 220 here in Texas. I ran a a few sips of sea foam through my intake manifold off a vaccuum hose, then the rest through the tank. Drove her like I stole her, took her back to test again same day, left her running until they were ready, and she passed.
Old Apr 25, 2012 | 07:39 PM
dtLS400's Avatar
dtLS400
I digg the drive it like you stole her bit. I'll try that mang I got 15 day free retest :/
Old Apr 25, 2012 | 07:45 PM
japsc85's Avatar
japsc85
change your oil you will be fine!!
Old Apr 25, 2012 | 07:46 PM
JustChill's Avatar
JustChill
Did u drive the car for a while before u smogged?
Old Apr 25, 2012 | 08:12 PM
Nysc300's Avatar
Nysc300
Clean your Erg valve
Old Apr 25, 2012 | 08:47 PM
GS4_Fiend's Avatar
GS4_Fiend
Post up the full readings including the 02% and C02%.
Old Apr 25, 2012 | 08:55 PM
XsirousX's Avatar
XsirousX
The correct abbreviation is "EGR"
Old Apr 25, 2012 | 10:11 PM
Nysc300's Avatar
Nysc300
Yeah I know. Didn't catch my mistake. I failed my smog test horribly a while back. I pulled the EGR valve off and passed.
Old Apr 25, 2012 | 10:29 PM
dtLS400's Avatar
dtLS400
Just did tune up the night before, oil , filter, spark plugs, wires, air filter, cleaned maf and throttle body as well as I could. Only the low speed shows up as fail high speed was fine.
Old Apr 25, 2012 | 10:31 PM
dtLS400's Avatar
dtLS400
I drove it for about 30 mins but never passed 60 mph, reason being it was raining and I have bald tires.
Old Apr 25, 2012 | 10:58 PM
GS4_Fiend's Avatar
GS4_Fiend
NOX should go up and it should failed for Visual inspection.
Old Apr 25, 2012 | 11:06 PM
g4ebguy90's Avatar
g4ebguy90
Hydrocarbons if fuel, so you running rich, I would also check EGR as that operates at low engine speed.
Old Apr 26, 2012 | 07:28 AM
dtLS400's Avatar
dtLS400
%co2. %o2
15mph. 14.6 .3
25mph. 14.7 .1
Old Apr 26, 2012 | 09:29 AM
GS4_Fiend's Avatar
GS4_Fiend
Originally Posted by dtLS400
%co2. %o2
15mph. 14.6 .3
25mph. 14.7 .1
I said full readings. Lol. HC,CO,NOX
