Please help . I allready bypassed ECU 2 years ago and been working fine. I filled the tank the other day and noticed a louder than usual humming coming from back seat. yesturday after a long run I parked it and it will not start nor is there a buzz from fuel pump when key is turned on before crank.
Is the fuel pump behind the back seat ? my car is slanting downward and when I began to remove fuel started pouring out. I have a little over half a tank. jacking the car up will prevent this?
I there anything else I need to know about replacing the fuel pump...any tips?
its behind the backrest of the back seat, you should try and have less then half a tank i believe, i did this a few weeks ago with alil more then a 1/3 looked pretty close to the access port but couldn't recall how close it was dark. once you open it up and take a flashlight to it, its pretty self explanatory 3 bolts hold the hanger and you have to slip off the feed hose that you will see right away
